Can one hear a switching power supply? - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th February 2013, 07:13 PM   #21
marce is offline marce  United Kingdom
Dont tune in, its a tinitus trick you learn, hard to explain how not to, but its possible, think of something else , read a book or watch some interesting TV. If you focus on the sound it does your head in.
Or get a new power supply, when they make noises they are often not far from failing, and fialure rates for PC's are PSU number one.
Old 28th February 2013, 08:09 PM   #22
kouiky is offline kouiky  United States
kouiky's Avatar
The router is a Siemens and the switch was a D-Link DIR601 and POE.
Its a shame that doctors and researchers haven't found a way to regrow nerves and the tympanic membrane back to the way it should be. I hope that they will in the future find a way to correct medical issues like your son experiences, marce.
Old 28th February 2013, 08:10 PM   #23
kouiky's Avatar
Old 28th February 2013, 10:52 PM   #24
Originally Posted by twu View Post
I am DIYing a headphone amp with a LDO regulator which has lower PSRR than regular regulators, can it effectively filter out the broadband noise generated by the switching P/S?
If you don't specify the noise and you don't specify the regulator you can't expect a sensible answer to this question. As stated, it's makes little more sense than asking 'how long is a piece of string.'
Old 28th February 2013, 11:45 PM   #25
Originally Posted by SY View Post
Back in the '60s and '70s, those drove me crazy. I hated the noise. I can't hear them any more, so my assumption is that they've improved the technology.
The unfortunate truth is that, like me, your hearing has deteriorated but also, there are a lot fewer of them around now..
Old 1st March 2013, 07:34 AM   #26
I think that was one of Sy's leg pulling posts...
Kouiky, my Lad is lucky, at least he can hear, and enjoys music, though I should imagine it sounds rather different, but as he's into hip hop etc and wants a pair of Beats headphones he isn't missing much
Old 3rd March 2013, 01:09 PM   #27
upstart is offline upstart  United States
There are several components in an SMPS you can hear, magnetic components undergo stress in response to changes in current, while ceramic capacitors undergo stress in response to voltage. If the SMPS feedback loop is not operating correctly, the switching waveform will have components in the audio band.
Switch mode power supplies (SMPS) generally have poor rejection of low frequency input signals (line harmonics) but do not pass higher frequencies from input to output (though they do introduce ripple of their own). A linear regulator has poor rejection of high frequencies, but very good rejection of lower frequencies.
From an electrical standpoint, following an SMPS with an LDO is valid, and a good practice. Placing a filter at the final output to eliminate switching noise (ripple) is a good idea. You are not trying to remove the switching frequency of, generally, 50 kHz to 1 MHz, but rather the fast edges associated with the switch. A filter with a cutoff of a few MHz between your SMPS output and LDO input will do wonders. Choose a cutoff that is 5 to 10 times higher than your SMPS switching frequency, or half the unity gain bandwidth of the LDO, whichever is lower.
In theory, there is no difference between theory and practice; in practice, there is.
Old 3rd March 2013, 01:26 PM   #28
Pano is offline Pano  United States
Pano's Avatar
Getting back to the original question (cough, cough) most 3 legged regulators have high output impedance at high frequencies. Most datasheets will show this. Some datasheets also show PSRR with frequency. It's usually worse as frequency rises. So the LDO regulator may not be very good at all up where the SMPS is making its noise.
That's the first thing to look at. If you have some way to do an FFT analysis of the SMPS output, you'll clearly see the noise. You can then test for noise after the linear LDO reg.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 3rd March 2013, 02:11 PM   #29
Kindhornman's Avatar
Pano,
It seems that you would have two types of problems to deal with with the smps supplies. One is the generation of RF and transfer through inductance into a following circuit and the primary you are talking about are the remnants of the high frequency components not being filtered through the wired connections to the next stage. Two separate issues needing two separate approaches to attenuate them.
Old 3rd March 2013, 02:25 PM   #30
Pano's Avatar
Yes, for sure. Switching amps also radiate noise all around, so you have to be careful.
Both direct and radiated noise are important to watch out for, thanks for bringing that up.
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
Switching power supply jhead Power Supplies 2 12th November 2010 03:20 AM
How to hear a power supply? glt Parts 4 6th April 2008 07:16 PM
Switching power supply Thomas B Pass Labs 15 9th December 2002 10:28 PM
Copyright 1999-2017 diyAudio
