adding current limiting to a power supply
Old 27th February 2013, 02:38 PM   #61
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Hey Elvee, when you quote me, don't edit off the parts you don't like.
You edited out the most important line:
Figure 6 . Current Limit
How low can you fall?
Thanks God you are not a Cop, or the following dialog might take place:
Scene: a dead guy with a shot through his head.
Officer one: "this guy has a shot in his forehead"
Officer Elvee: "NO ! NO! NO!! ABSOLUTELY wrong!!! this guy does not have a shot through his forehead, he has a 9mm shot through his forehead !!!!"
Thanks for being so funny, better reading your desperate posts than watching some comedy at Sony Channel.
Old 27th February 2013, 07:51 PM   #62
Elvee is offline Elvee  Belgium
Elvee's Avatar
..../snip crap/....
What do you think happens to the graph, or §6, or the current, or anything when the die temp exceeds 160°C?
How do you call current falling in this case? Special name just made up for the occasion just to avoid the word "limit"?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 27th February 2013, 07:58 PM   #63
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
@Elvee setting aside anything that might have been sayd untill now, i have a honest question and i need a honest answear:
-Do you honestly think the case temp can or should be allowed to reach 160deg? nevermind what the datasheet says, what do you say? do you allow it to go that far?
Have a go at my latest set => Dj Marik -
Trance session live ep. 94
Old 27th February 2013, 09:56 PM   #64
JMFahey's Avatar
>>&&&&&&&&&&&&&&&&&&&&&&<< <--MISSING LINE
..../snip crap/....
You did it AGAIN !!!!
Second time you quote me editing out the basic phrase!!!
Are you out of your mind?
Old 28th February 2013, 07:16 AM   #65
Elvee's Avatar
OK, that's an honest question, I will answer honestly: taking any device, particularly a plastic one beyond 150°C is generally not a good idea, even though the datasheet claims it can withstand "indefinite short" (beware of datasheet claims!).
But here the problem is somewhat different: as I said above, the dissipation in case of an overload will be practically sufficient to bring the die to 150°C, with the mounting base still at ~25°C. This means that most of the case will be at a reasonable temperature, with just the very heart of the chip at 160°C.
OK, it still creates thermal stress, etc, and that is not the kind of thing you want to abuse of, but in the case of the OP, the goal is to have a sort of automatic resettable fuse to protect the transformer.
Such an arrangement will work in this case: the initial overload current will be comprised between ~2.5A and 1A depending on the I/O differential, and most of the time that will be sufficient: the 317 will not have the opportunity to heat up to the thermal protection temperature, and the user of the supply will notice the voltage has dropped, and react accordingly.
If this situation lasts too long, the heatsink will heat up, and only then will the temperature reach 160° and reduce the current to a safe level.
That is not something that is going to be used systematically (hopefully).
A suitably sized PTC or polymer fuse could provide a similar kind of protection with the original 338, but the difficulty will be in choosing exactly the right one.
The advantage of the 317 and other "thermal" solutions is that they allow some overcurrent for some time, which can be useful to test amplifiers for example: a normal current limitation will clip each peak >1A on a cycle by cycle basis, even if the average current is much lower, but here there is a provision for more than twice the normal current provided things do not get too hot for too long.
It may not be the perfect solution, but I think it is a good trade-off that suits the needs of the OP. Additionally, it is simple to implement, predictable, and it doesn't in any way degrade the original performances of the regulator.
I answer to honest questions only, not provocations.
Old 28th February 2013, 07:34 AM   #66
JMFahey's Avatar
So my quoting exactly what the datasheet says is a provocation?
Tsk, tsk, I think we have a problem here.
Old 28th February 2013, 07:48 AM   #67
MarianB's Avatar
@Elvee, i'm Happy to see that we are on the same page. Granted LM317 seams a better ideea that it's big brother, but anything will be used it will require a fuse rated so as it will blow at shorted ouptut cus in that case the reg will dissipate a great deal of power, so if let say the Vin is 24Vcc and the limmit at 2A that means over 48W of power will be dissipated by the regulator prior to overtemp prot comes in, if ther fuse is well rated than it will blow up as soone as the output will be shorted, and the fuse holder can be a pannel one so it can bea easy replaced, this way the unit is well protected but still as you say, it is not a verry good ideea to abuse it...
Another saolution could be this in the attachement, the current limit is the same with overload as with shorted output, there will be a few tens of volt drop on the series pass resistor depending on the load current but i think it can be worth it in many cases, the only real vdrop will be at current limmit when the voltage delivered to the load will drop in order to maintain the current, the limmit is verry precise and with a sturdy mosfet there should not be any problems, i luv IRF3205, especially it's Rds-on but the T220 case not so much... something in T247 case with as littl Rds as possible could be the answear in many cases.
PS: Agreed, LM317 only seams the best solutios here, but there can be sutiatuations in witch this CCG could be usefull.
Old 28th February 2013, 08:35 AM   #68
Elvee's Avatar
That is indeed a possible solution, much better than trying to meddle with the regulator itself.
To make it completely transparent, it should be placed upstream of the regulator, and to make it safe, a 12V zener should be added between the gate and source of the MOS.
Old 28th February 2013, 09:33 AM   #69
dietnews is offline dietnews
hi guys,
thanks for all the information. my plan for now is to replace the LM338 with a LM317 and add a fuse to the transformer's secondary in case of a short circuit. i would like to have a little wiggle room to overload the LM317, for when testing homemade amplifiers, without blowing the fuse while still providing protection in the case of a short circuit. would a 2.5A fuse be a good choice?
also, i'm interested in setting up a crowbar circuit but honestly i'm not really sure what situation it applies to. i dont think i've ever experienced an "overvoltage." what causes that?
Old 28th February 2013, 09:42 AM   #70
R.I.P.
fit a close rated (CL) fuse in the primary circuit of the transformer.
Normal fuse for a transformer:
Fuse Rating = VA / Mains Voltage * 3
Close rated fuse for a transformer:
CL Fuse Rating = VA / Mains Voltage
regards Andrew T.
adding current limiting to a power supplyHide this!Advertise here!
Audio Amplifier, Current Limiting Voltage Supply problem efevi Class D 11 13th January 2013 09:25 PM
current limiting for power supply akis Power Supplies 49 13th November 2010 12:21 PM
Adding capacitors to power supply jmillerdoc Chip Amps 4 13th April 2009 05:48 PM
Does any power amp have a current limiting device? beppe61 Solid State 44 22nd December 2005 11:47 PM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
