adding current limiting to a power supply
Old 26th February 2013, 12:05 AM   #31
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
The circuit posted on #10 has all that's needed, both high precision voltage source and safe current limiting, just a couple parts need to be moved around.
But no need to add extra regulators or switch chip type.
Old 26th February 2013, 07:34 AM   #32
dietnews is offline dietnews
marianb, what value would you use for R4 in your schematic?
Old 26th February 2013, 08:17 AM   #33
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
About 100 Ohm should be ok, it's role is to protect the BJT in case of shortcircuited output.
Have a go at my latest set => Dj Marik -
Trance session live ep. 94
Old 26th February 2013, 08:23 AM   #34
thanks. what power rating should it have? same as R3?
Old 26th February 2013, 08:30 AM   #35
MarianB's Avatar
No, about 0,5W should be fine.
Old 26th February 2013, 08:45 AM   #36
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
I would actually move only one...
An other advantage with it is that you can also use the R3 as the shunt for an ammeter! Which is nice...
Old 26th February 2013, 08:57 AM   #37
MarianB's Avatar
Originally Posted by palstanturhin View Post
..you can also use the R3 as the shunt for an ammeter! Which is nice...
Didn't thougt of it but yes it woud work just fine that way
Old 26th February 2013, 12:38 PM   #38
Elvee is offline Elvee  Belgium
Elvee's Avatar
high precision voltage source and safe current limiting,.
Depends on the meaning of "precision" and "safe": in this case, a worst case error of 50%, and a current that can reach ~4A.
There is also the unresolved issue of loop stability in the current limit mode.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 26th February 2013, 01:26 PM   #39
MarianB's Avatar
That worst case scenario of voltage regulation less precission would be at the minimum Vout/max Iout, i doubt this unit will power something that sensitive... for real performance lab power supply a much more powerfull transformer is rerquired along with much more complex regs... this unit i think it is just good enough for general testing. As for that 4A, that will only be at shorted output, witch u do not seam to get it that this circuit is not intended, a 2A fuse along with this circuit will make sure nothing bad will happen with it, the regulator will be able to witstand the stress for those few seconds untill the fuse blows up as for the power transformer, well, if a 50/60Hz transformer blows up at the first shorted output then the hell with it, it's not wort anything.
So thing is either you do not see, don't want too see that you are just looking for problems where they are not... as i sayd, this cind of behaviour it is sad...
Old 26th February 2013, 02:10 PM   #40
JMFahey's Avatar
You have no idea.
"Precision" refers to the built-in precision of the regulator.
Just check the datasheet.
Does it state 0.1% or whatever? Well, that's what you'll get.
50% error?
Not even an unregulated supply will be that bad
Current can reach 4A ?
Who says so?
Didn't I tell you the OP can current limit it to *any* value he wants?
Loop stability in the current limit?
Don't worry about that , all these regulators are *designed* to be able to be current limited.
No designer worth his salt will release an unstable design.
By the way, palstanturhin *instantly* understood what I am talking about.
And he also thought about another practical use, go figure.
No doubt many others did too.
Think a little and you will too
adding current limiting to a power supplyHide this!Advertise here!
Audio Amplifier, Current Limiting Voltage Supply problem efevi Class D 11 13th January 2013 09:25 PM
current limiting for power supply akis Power Supplies 49 13th November 2010 12:21 PM
Adding capacitors to power supply jmillerdoc Chip Amps 4 13th April 2009 05:48 PM
Does any power amp have a current limiting device? beppe61 Solid State 44 22nd December 2005 11:47 PM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
