adding current limiting to a power supply - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th February 2013, 08:17 AM   #11
Originally Posted by MarianB View Post
Only when reaching the threshold the output will be affected, but then again any current limmiting acts about the same, it reduces the voltage to keep the current at a needed level, so no problem here.
Easy fix:
hmm, so the current limiting shouldn't impact voltage regulation until i reach the current threshold? what happens at that point? the voltage drops slightly?
would a 2n3904 be a suitable substitute for the BC546A? do i need a heatsink on the BJT?
R4 = 0.65 / Iout. so if i want to limit at 2A then R4 = 0.325ohms? what power rating will i need on this resistor?
Old 25th February 2013, 08:36 AM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
a) It will impact the regulation at any current level
b) On a dead short, the current limit will be double the normal
A LM317 is cheap compatible with the LM338, does the job perfectly and won't lead you into troubles like oscillations
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 25th February 2013, 08:42 AM   #13
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
Current limiting ( aka constant current generator ) work like this: When some chosen threshold is reached the voltage is dropped so the current chosen can be maintained, you cannot have the same voltage and same current for any load level, let say you have a resistive load of 10 Ohm and an output voltage of 20V, that makes a load current of V/R =>20/10 =>2A, now let say we drop the load to 5 Ohm but we want the same voltage on that new load and the same 2A, well that is impossible cus as we have pointed out already I=V/R =>20/5 =>4A; what then? well if we need the same current we drop the voltage, and V=I*R =>2*5 =>10V. That is how current limmiting works, it reduces the voltage to maintain the current in needed limits.
Any NPN small signal transistor will do as long as the Vce of it it's larger than any espected Vin on the regulator ( that is just to be sure ), it does not need a heatsink cus it will work only when the limit is reached and it will dissipate a small enough power, the resistor indeed would have to be 330m Ohm for 2A limmit and it's power rating P=V*I =>0,65*2 =>1,3W, make it 2 or 3W.
Originally Posted by Elvee View Post
a) It will impact the regulation at any current level...
No, it will not, maybe you should study more of this config... as long as the voltage across the shunt resistor is less than 0,5-0,6V the transistor will not enter conduction, and let say that the load is 1A, on a 330m Ohm resistor will be 330mV, that is too small a voltage to biass the BE of it, so no, only near the threshold when Vbe will be big enough the regulation will be affected.
a) b) On a dead short, the current limit will be double the normal...
The regulator already has internal shortcircuit protection and so it will not be affected, and the NPN will be protected by the base resistor, so nothing bad can happen at a shortcircuit, and anyway nowone will short a PSU just for the fun of it, that can only happen accidentaly so in short periods/time and as i have pointed out it cannot affect the regulator.
..A LM317 is cheap compatible with the LM338, does the job perfectly and won't lead you into troubles like oscillations
There are no oscilations here, both the regulators are about the same, only this one can handle more current, on the other hand LM317 would only giv about 1,5A, and here it is needed 2A, i think it is the best way to go.
Have a go at my latest set => Trance Session Live ep 67
Old 25th February 2013, 08:51 AM   #14
sofaspud's Avatar
There has been replies while I typed, but I'll add this anyway.
I don't remember seeing this circuit before, but it seems easy enough. It's sort of the series pass transistor concept in reverse. When the R4 IR drop reaches a level to turn on the transistor, current is shunted away from the adjust pin. That reduces the regulator output voltage, and also the current.
It will impact the regulation at the load; there will always be a drop across R4 that is unseen by the regulator.
A 2N3904 can substitute. No heat sink needed.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 25th February 2013, 08:59 AM   #15
MarianB's Avatar
Yes there will be some voltage drop on the shunt but small enough though, anyway if mV precission and current limiting is needed then this tipe of regulator will not do, then more complex regulators should be used, but i am sure that is not the case here, a couple of hundreds mV of voltage drop will not be souch an issue.
Old 25th February 2013, 09:20 AM   #16
Elvee's Avatar
No, it will not, maybe you should study more of this config... as long as the voltage across the shunt resistor is less than 0,5-0,6V the transistor will not enter conduction, and let say that the load is 1A, on a 330m Ohm resistor will be 330mV, that is too small a voltage to biass the BE of it, so no, only near the threshold when Vbe will be big enough the regulation will be affected..
You should probably study more carefully this configuration: the 0.33 ohm is in series with the output, and it will add an uncertainty between 0 and 0.6V on the output voltage. This makes it useless as a lab supply. If you set it 3.3V to supply logic circuits, it could drop to 2.7V under load.
The purpose is to protect the transformer and rectifier against overloads.
If the limitation is incapable to do that in case of a short, it defeats its usefulness.
When you add loop gain (transistor) to a regulator, you eat up the stability margins
Old 25th February 2013, 09:30 AM   #17
KatieandDad's Avatar
Why not use 2 LM338 circuits. The first to current limit, the second to voltage stabilise.
Old 25th February 2013, 09:34 AM   #18
MarianB's Avatar
@Elvee you seem to enjoy contradicting me just for the fun of it...
ANY active current limiting would imply a shunt resistor and so a voltage drop on it, but it is small enough so you are not worryed, and for the life of me i cannot understand what is souch a BIG issue few tens of volts drop? the author did not mention the exact purpose of the supply, but as i sayd mV preccision and preccision current limmiting is not likely to happen with thys tipe of regulator.
On the other hand, yes the config really has overload protection witch is different from shorted outputs, you cannot hope to have a linear regulator imune to indefinitly shorts on the output without serious upgrades, and so you make sure that any shorts will be... whel short in time, and any 50/60Hz power transformer can cope with shorted outputs for a max of a few seconds, but not even that would not happen, you guess why.
This woulb be much more precise on voltage regulation but the current limmit is not so, you rely on the regulator's limmit of about 1,5A and the rest of the current is given by the pass transistor
Old 25th February 2013, 09:42 AM   #19
Just looking at the datasheet
http://docs-europe.electrocomponents...6b80028b1f.pdf
On page 8 you can see how the LM338 is used in current limiting mode. AFAICR you need to keep the adj pin at <1.25V. So if you want to limit the current to 1.5A you are looking at using R(limit) = 1.25/1.5 = 0R82.
Unfortunately the second regulator will swallow another 3.5V of your available ouput.
Old 25th February 2013, 09:50 AM   #20
MarianB there are Trolls on all the forums. Just ignore them.
Audio Amplifier, Current Limiting Voltage Supply problem efevi Class D 11 13th January 2013 09:25 PM
current limiting for power supply akis Power Supplies 49 13th November 2010 12:21 PM
Adding capacitors to power supply jmillerdoc Chip Amps 4 13th April 2009 05:48 PM
Does any power amp have a current limiting device? beppe61 Solid State 44 22nd December 2005 11:47 PM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
Copyright ©1999-2017 diyAudio
