Dear All,
I have a question with this design for PS The input is 320 V AC and the out put is 400V DC I am wondering why Resistor #5 (68K 3W) always very hot? Can some one give me some clue? tks |
#2 |
what is the dissipation of that Resistor #5 (68K 3W)? in my case, i use that 3 watt to dissipate less than 1 watt...
http://www.elab.ph/forum/index.php?topic=32688.0 |
#3 |
Does it actually work at all? I really don't see how you could subject an LM317 to these voltages. How could you send AC straight through a 10mH inductor? What happens if you put 100uF straight over AC? Where does the DC come from? Etc.
Second law is your friend. Last edited by vacuphile; 23rd February 2013 at 10:25 PM. |
#4 |
That was my initial thought, too, vac. But he has a rectifier box there on the AC input. I don't understand the zener bypass, or the pot wiper to nowhere, or...
so best for me to leave it alone.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#5 |
Sofaspud,thanks, had overlooked it. And you are also right about your last point.
Second law is your friend. |
#6 |
the zener could be a 27volt one, together with the mje13005 ensures that the vin-vout rating of the lm317 is never exceeded....
#7 |
Sure. I should've realized. Thanks, Tony.
#8 |
welcome, the circuit reminds me of the maida regulator....21st Century Maida Regulator
#9 |
You are completely right!
#10 |
LM 317 adjust pin is 1.25 V below output V. R5 dissipates about 2.35 W = (400-1.25)^2/68000.
The 5k pot is much too large. For 400 V out you need about 213 Ohms there, so you will be using only 4% of the pot, voltage adjustment will be way too sensitive. |
| Wrong Voltage / current on BoZ... or Wrong Measuring ? | gionag | Pass Labs | 8 | 14th May 2008 11:24 AM |
| Is % open area the wrong parameter for ESL stator design? | Few | Planars & Exotics | 6 | 23rd May 2007 09:58 PM |
| help!!! design a T-line enclosure for the "wrong woofer" | ningures | Multi-Way | 4 | 7th October 2006 07:24 PM |
| Anything wrong with my first sub design? | angsuman | Subwoofers | 9 | 23rd November 2005 01:38 AM |
| Anything wrong with this design? | FrancoB | Tubes / Valves | 4 | 27th April 2005 06:50 AM |
