PSUD high ESR question - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th February 2013, 04:51 PM   #21
SY's Avatar
Originally Posted by udailey View Post
Same with .026R 1500uf throughout just for direct comparison to last pic with 1R transformer
That looks right.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th February 2013, 05:17 PM   #22
udailey is offline udailey  United States
Agreed. I just wanted to show how the standard schematic simulates vs the 100r ESR. The one that looks right is the standard values.
I know PSUD is giving false values but at what point do the values stop simulating reality and start being totally false? If I sim with low ESR cap at .026R and then use the same cap with 1R or even .05R the numbers look like less noise.
So it seems like its not just with large ESR that it gives false results. Ill show you. Here is a schematic with .02 ESR, .08ESR and 100ESR caps. Each of first twoare rather normal and last is extreme but common to all is higher ESR = lower noise.
Each has better noise than the previous. Does PSUD work at all considering this?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 14th February 2013, 11:52 PM   #23
Could it be the resistance of the capacitors you have in the sim? I usually just plug in 1 Ohm there....
Bob
Old 15th February 2013, 03:18 AM   #24
Any sim I do is effected by an increase in ESR and the results are always better noise with higher ESR. Kinda backwards.
1 ohm is a lot. .026 is truly the resistance of the Rubycon ZL 1500uf 25V caps.
Old 28th March 2013, 02:08 AM   #25
I simulated a pp tubeamp with circuitmaker and got below 1ppm!!! thd at full power.
To bad reality wont match simulated results, but I'll settle for 100ppm
Old 12th September 2014, 02:36 PM   #26
I found an article on Planet Analog ( I think it was linked to by someone in one of Gootee's cap decoupling/paralelling threads). Here is the article
Planet Analog - Articles - Know the sometimes-surprising interactions in modelling a capacitor-bypass network
It shows how in the many megahertz range a higher ESR allows a overall lower impedance to higher frequencies. Do you think PSUD is simulating this behavior?
Their summary is pasted below. See point 5
Summary
Here's a summary of bypass considerations raised by this article:
1. Bypass close to IC pin and ground (minimize Rseries for deep notches, optimize it for smoother overall impedance)
2. Use multiple values in broadband applications (or in the presence of broadband noise), spacing the resonant frequencies out over the band you need to cover
3. More capacitors won't hurt the power supply! They just add area, cost and design time.
4. To be sure, simulate (any simulator will do, even a free one). Quantify parasitics and model correctly, applying common sense to the component parasitic values
5. Loss can be good! Higher-performance capacitors may not be best in your circuit.
6. Resonance (impedance nulls) can be useful, be sure to predict and employ
7. Anti-resonance (impedance peaks) can get you into trouble, so predict and avoid!
Old 12th September 2014, 03:04 PM   #27
Another article talking about the increase of ESR allowing a smoother supply
Yet more on decoupling, Part 2: Power supply excitation and ringing | EE Times
They are talking about caps directly after an LDR but nevertheless we see that just large capcitance isnt the cure all. Some ESR is good along with bypassing the large cap.
Here is their summary:
Takeaways from this part:
Whatever the LDO datasheet says, high-ESR output capacitors give better control of high-frequency supply resonances
The smaller you make the main ceramic decoupling capacitor, the faster and larger will be the ringing that occurs on a load current step - this is a small-signal effect and occurs for any current change, not just large ones.
If you are designing audio circuits that don't have impeccable power supply rejection, the LDO regulator impedance bump could cause coloration as it usually occurs within the audio band. Huge output capacitors don't cure it, in fact they could make it worse. Use that noise bypass connection.
Old 13th September 2014, 03:56 PM   #28
Triodethom's Avatar
Zorbel circuit or tuned resonator in the rf range with high esr.
PSUD question SHiFTY Tubes / Valves 6 8th March 2008 11:11 PM
FE 206 ESR mid high ? Lagroute Full Range 9 11th January 2007 02:22 AM
Low ESR capacitors and high operating temperatures KT Parts 2 24th September 2005 08:12 PM
noob PSUD question... roundel325 Tubes / Valves 8 8th April 2004 03:10 PM
Copyright 1999-2017 diyAudio
