Voltage doubler?
Voltage doubler?
Old 10th February 2013, 08:21 PM   #1
famousmockingbird is offline famousmockingbird  United States
Default Voltage doubler?
I am not sure but this looks like a voltage doubler? It is for a tube amp and I think that it probably can be upgraded or redesigned maybe, most voltage doublers I have seen have about double the components. If someone could please explain what is going on here it would be much appreciated.
Old 10th February 2013, 08:35 PM   #2
Ketje is offline Ketje  Belgium
Ketje's Avatar
It's rather simple realy.There are two halfwave rectifiers.The positive one goes though D101 charging C101 and the negative half by D102 to charge C103 with it's lower end at gndlevel (just outside the picture).Since one is on top of the other you get dubble voltage.
Mona
Old 10th February 2013, 08:44 PM   #3
Why would this be used instead of say a bridge rectifier? I usually see a full wave bridge rectifier on most designs.
Old 10th February 2013, 08:58 PM   #4
Ketje's Avatar
Economical reasons I suppose.If you put a extra idental winding on the transfo with two diodes to C101 and C103 it becomes a bridgerectifier.In stead off a 60Hz ripple it is now a 120Hz smaller one.Normaly that's better but if it isn't nessesairy why make the extra cost.
Mona
Old 10th February 2013, 08:58 PM   #5
djgibson51 is offline djgibson51  New Zealand
Thoughts that come to mind;
1. Bridge rectifier has a theoretical output voltage of 1.41x - not 2x
2. Don't have to throw away voltage for stages downstream through resistors
Cheers
JimG
Old 10th February 2013, 09:10 PM   #6
3. Only need 350v smoothing caps.
Old 11th February 2013, 08:44 AM   #7
payloadde is offline payloadde  Europe
payloadde's Avatar
can be used to get symmetric -250v / -0 / +250v from a single transformer winding
or two different voltages like +250v / +500v from a single transformer winding
depending where you put "ground"
- is sometimes mis-labeled Greinacher Circuit (should be named Delon Circuit though)
Jochen's High Voltage Page : Basic multiplier circuits
Voltage doubler - Wikipedia, the free encyclopedia
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 11th February 2013, 12:26 PM   #8
Thank you so much for this explanation!!!! I was thinking of a Greinacher Circuit in my head which is different. It is indeed a Delon circuit!!!!!
Voltage doubler?Hide this!Advertise here!
Voltage Doubler ????? Dagwood Power Supplies 4 6th November 2011 02:30 PM
Transformer for voltage doubler? markusA Power Supplies 10 13th February 2011 11:40 AM
Need help with voltage doubler Lingwendil Power Supplies 6 22nd April 2009 12:15 AM
Voltage Doubler jwatts Tubes / Valves 3 2nd January 2009 12:13 AM
Voltage doubler Baard Solid State 28 17th January 2005 04:46 AM
