#21 | |
"Epilepsy medications are a lot like girlfriends. Sometimes you just have to take what you can get." -- Dr. Mark Quigg |
#22 | |
Shall let him escape with just wrists slapped? ![]() 1 - it does. 2 - time to start. Call me non-progressive but I would 'never' do class D BUT given the conditions (12V, space, etc) and your scale, I don't see a real alternative. There are some excellent threads here to get you started! |
#23 |
+/-2V but Id prefer constant really.
#24 |
OK, then you need the outputs voltage controlled.
I recommend not going much higher than 200-300W per transformer. You can keep the losses at a more reasonable level that way... Google for TL494 and SG3525 to begin with. |
#25 |
Thanks for that I will look into it
| +-45vdc regulated power supply schematics needed. | Maroof | Power Supplies | 49 | 2nd September 2012 07:30 PM |
| SMPS 12VDC to +-45VDC | Luciperro | Car Audio | 11 | 6th June 2007 12:01 PM |
| 15vdc amp | bjackson | Chip Amps | 6 | 18th August 2005 12:52 AM |
