#11 |
Should I knock it down to two caps?
I will of course fuse the primary :-) |
#12 |
I'd would at least start with two. That should be plenty. More could be added if necessary, but then I might try CRC filtering or regulation before that.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#13 |
Thanks for all you help.
| Need a 2W Bipolar DC - DC Converter circuit to make a dual rail power supply | elmura | Power Supplies | 2 | 27th August 2012 08:30 AM |
| DC-DC variable voltage and current lab power supply | bengaltiger | Power Supplies | 13 | 1st August 2012 08:50 PM |
| DC>DC power supply for DEQX | Antonyhu | Power Supplies | 4 | 8th December 2011 09:02 PM |
| use of dc-dc converters in high power amps supply | guyst | Power Supplies | 0 | 13th April 2010 03:12 PM |
| DC-DC Power converter for Class T amp power supply? | rtalk | Class D | 2 | 7th December 2004 04:02 AM |
