Power transformer ratings and cross-sectional area. - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th April 2013, 09:31 AM   #22
Originally Posted by gorgon53 View Post
The core must have as little airgap as possible and a winding with a known number of turns on it. Use a variac to feed the coil. Start at some low voltage and measure voltage and current. Take notes and calculate the impedance. Increase the voltage stepwise and caculate the impedances. With increased voltage the impedance will increase until it reaches a maximum. This is the point where the core has the highest impedance. Now divide this voltage with the known turns and you have the V/turn that givs the highest impedance/turn
Thanks for that.
I see that you are describing what can be seen when one plots the Iprimary vs Vprimary curve.
The S shape that results shows the steepest I/V when the tangent to the S curve is used as the Turns per volt.
I have used that same S curve to determine a much higher flux that still stays away from the saturation region. This nearly always requires some extra primary turns for our typical UK voltages. I have in the past recommended adding 20T to the primary. I find that few extra turns makes a significant difference to the core losses.
But it never gets down to that target shown with the tangent to the S curve you have described. I suspect using the highest impedance would require 50% extra primary turns and result in 2/3 of the output voltage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th April 2013, 03:27 AM   #23
Originally Posted by AndrewT View Post
Thanks for that.
Hi Andrew,
First of all thanks for having a fruitful discussion now.
Your interpretation of what i described is correct. Offcourse in any transformer design you have to set the priorities first and then adjust the unavoidable compromises accordingly. Given the priorities of a manufacturer it is for us DIY-folks, in a mains transformer that we use in a audio project, usually beneficial to increase the primary turns. By how much, 20T or whatever, depends on our individual priorities and the reqirements set by the load and the actual tranformer at hand. Most propably, despite the added turns, you will still be in the region nearer to saturation than to maximum inductance. To add primary windings to the point to get the highest impedance would seldom be practically possible because it would in most cases require even much more than 50% extra turns with the result of accordingly lower output voltage, power a.s.o.
Never the less, if size, weigth and purchasing costs does not restrict, even in a mains transformer with M6 working at 0.8T has his merits as long as you can cope with the downside effects in a non degrading way.
In a OPT with M6 iron 0.8T at the lowest frequency givs the highest impedance at the frequency where it is most needed, but it is good to remember also, that 0.8T is only the steady state value. Music is not steady state so to prevent excessive distortion at the very start of a low frequency full power event it would not be a entirely bad idea to use even lower flux densities.
Then again, it will bite you at the other end of the passband....
What is the best compromise depends on so many things, source impedance, feedback a.s.o.
I think you know all that, may be others dont, so i just putted here what came into my mind of possible being useful...
Determining the core cross sectional area, Afe, for SE OPT Tyimo Tubes / Valves 11 17th September 2012 08:12 PM
cross sectional area shapes gafhenderson Full Range 5 3rd April 2012 04:23 AM
confused on power transformer ratings nightanole Tubes / Valves 21 26th August 2010 08:08 PM
Transmission line cross-sectional area question h@kan Full Range 11 26th October 2009 11:18 AM
Power supply transformer ratings deskmate88 Chip Amps 4 29th January 2004 05:29 AM
Copyright 1999-2017 diyAudio
