do someone now this ic. - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th January 2013, 02:42 PM   #1
kees52 is offline kees52  Netherlands
Default do someone now this ic.
Hi All
I have a switched supply who has the 3nc60fb fet and a 8 pin driver ic, the fet was defect, but only between drain and source, the 100 ohm resistor and the diode across who go to the gate are oke, shall then the ic also oke?
I can not find the proper ic on the internet do someone now this ic 8 pins L656S
also two rectifier diodes die and bad caps who are the reason of blown.
I can not find a doc about it.
thanks
kees
Old 26th January 2013, 10:09 PM   #2
payloadde's Avatar
is possibly L6565 from ST
http://www.datasheetcatalog.org/data...cs/mXyuyxt.pdf
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 27th January 2013, 02:16 PM   #3
Thanks, this is it.
regards
What IC should I use? CorySCline Chip Amps 25 5th September 2011 06:36 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 05:58 PM
What is the difference between an isolated IC and a non-isolated IC? DJ Exprice Chip Amps 16 20th June 2006 07:34 AM
Copyright 1999-2017 diyAudio
