Problem with Sugden Optima amp - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th January 2013, 11:44 AM   #1
Default Problem with Sugden Optima amp
Hi all, I have a Sugden Optima 200 amp which I purchased in about 1996. It is solid state. It recently stopped powering up. Symptoms are: power light comes on but no audible click after about 5 sec and no sound output. Remote volume control still works. I suspect power supply is faulty. PSU is Antrim toroidal model 2998x part no 01849 428734. I can't find any specs for the PSU. All fuses have been checked for continuity and appear OK. Does my diagnosis sound correct? What causes the audible click in a solid state amp when the unit powers up. Is it a relay? Is this possibly the problem? Any advice greatly appreciated.
Glenn
Old 27th January 2013, 01:10 AM   #2
nigelwright7557's Avatar
The relay could be a soft start relay or a speaker relay.
I would check for volts across the main smoothing capacitors as a first port of call.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
NEED 2SK225 & 2SJ81 FETs for Sugden amp! Help! milosz Parts 25 21st January 2016 08:53 AM
JVC Optima 4s xl-z1010 vs. Optima 5s xl-z1050 cburbank Digital Source 8 17th January 2014 11:43 PM
Sugden a21a power amp repair adamus Solid State 12 11th January 2014 05:29 AM
Sugden CD21SE strange logic problem. Design fault ? Mooly Digital Source 1 28th March 2011 05:07 PM
Sugden A21a power amp schematics? Fyhr Solid State 4 11th December 2007 07:12 PM
Copyright 1999-2017 diyAudio
