High voltage, programmable power supply? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd January 2013, 12:34 PM   #1
Default High voltage, programmable power supply?
Does anyone know of a high voltage supply design (400v~ ish, regulated), that can be controlled via a smallish analogue voltage, and go down to near 0 volts? It's not for an audio supply in particular, but rather a digital curve tracing rig with several million data points. I've done a similar thing with adjustable voltage regs, by feeding a DAC output to their Vref pin. The only difference is that I was controlling 30 volts, not 400.
I know there are the Maida type, but the voltage is usually controlled by a resistor that has some serious dissipation. I could do the whole relay/binary ladder thing, but it seems a tad ineffecient. Are there any other topologies I should be aware of?
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 08:57 PM
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 03:21 AM
high voltage power supply leemajcool Power Supplies 3 5th August 2007 12:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
