diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   ? Re Adcom GFA 555ii (http://www.diyaudio.com/forums/power-supplies/228373-re-adcom-gfa-555ii.html)
Ccdave 22nd January 2013 02:57 AM
I'm considering replacing the 4 large caps in my Adcom 555ii amp with Nichicon gold tune caps. My ?'s are:
Does the large power supply caps influence sound?
How long do these large caps last?
One of the large original caps is starting to leak and I have already added the bypass caps and replaced all other existing caps with Elna Cerafines.
Triodethom 23rd January 2013 03:09 PM
Originally Posted by Ccdave (http://www.diyaudio.com/forums/power-supplies/228373-re-adcom-gfa-555ii-post3336747.html#post3336747)
cap life is based on time and temperature. Leaking indicated they are gone . The amount of influence on sound is based upon the circuit and its psrr (power supply rejection ratio). The short answer in this amp yes.
Ccdave 23rd January 2013 03:21 PM
gootee 24th January 2013 03:07 AM
The sound is DIRECTLY PRODUCED by the current from the capacitors, and from any decoupling caps (and occasionally by the current from the rectifiers).
See the image at: http://www.diyaudio.com/forums/power...ml#post3117390
Resources saved on this page: MySQL 18.75%
