Mounting of electrolytic capacitor
Old 21st January 2013, 03:01 PM   #1
Vrystaat is offline Vrystaat  South Africa
Default Mounting of electrolytic capacitor
Gooday all,
I have got big electrolytical capacitors 67000 uf 100v that I want to use in an amp. They are too tall to fit in the chassis that I want to use. It seems that they would normally be mounted vertically, I just wondered if it would be safe by mounting them horizontally to fit in the chassis. Can I expect problems by doing this ?
Jan
Jan
Old 21st January 2013, 03:14 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
No problem. They can be mounted in any orientation. Keep them away from hot objects.
Frank
Old 21st January 2013, 03:21 PM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
This was covered once before and folks came up with the strangest of answers, but, yes they can be mounted in any orientation.
Airplanes would be in trouble if they couldn't be.
Old 21st January 2013, 03:35 PM   #4
Thanks for the advise you guy's, now I have more peace of mind ! They are quite old but still looks good. I'll first try to reform them and see what happens. They are LCR caps. I have got a lot of Siemens caps too.
Jan
Jan
Old 21st January 2013, 04:29 PM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
yes, it should not be a problem
even upside down should be ok
only 'exceptions' would be when used in dangerous environment
like when mounted close to crutial important curcuits, should the pressure relief valve let out acid
btw, I don't think airplanes use this kind of lytics, but I don't know
Mounting of electrolytic capacitorHide this!Advertise here!
Electrolytic Capacitor Blown up wiredmonkey Chip Amps 9 9th March 2010 06:29 PM
Electrolytic Output Capacitor Kashmire Pass Labs 30 13th December 2007 09:59 AM
electrolytic capacitor source oldheathkitphil Parts 2 22nd June 2007 07:25 PM
electrolytic can capacitor el capitan83 Parts 3 18th December 2004 04:01 PM
Electrolytic Capacitor Insulation runeight Parts 2 22nd December 2003 06:20 AM
