Series power amp supply
Old 20th January 2013, 09:45 AM   #1
karellen is offline karellen  Spain
Default Series power amp supply
Hi
I have a toroidal trafo of around 40 V sec and want use it for a stereo power amp. As it donít have center tap and I donít want to use classic output capacitor topologies, Iím thinking on use a pair of class D amplifiers.
The problem is that the class D amps Iím thinking of donít like more than say 30V supply.
So the question is: May I wire the two modules in series so each one draw half the voltage of the trafo?
Or..
At idle the amps will draw only a few volts and will be over voltage destruction.
The failure of one channel will destroy the other channel
The over voltage protection of the modules will have very hard times
The use of VDR will help orÖ will burn a lot of VDRís
Thanks on advance
A cold amp is a sad amp... I like them warm at least
Old 20th January 2013, 09:47 AM   #2
R.I.P.
No.
regards Andrew T.
Old 20th January 2013, 09:48 AM   #3
R.I.P.
Buy the correct transformer.
regards Andrew T.
Old 20th January 2013, 09:56 AM   #4
thanks for the fast response.
Itīs a pity, cos seems a good trafo, rougly 400W from a wrecked Beomaster 6000
Old 20th January 2013, 11:43 AM   #5
Cro maniac is offline Cro maniac  Croatia
Cro maniac's Avatar
Wouldn't two amplifiers in bridge configuration run from single supply defeat the need for output capacitors ? Each output would be half the supply voltage and speaker would see zero DC. Like it was done on older car radio chip amplifiers.
Series power amp supplyHide this!Advertise here!
Odd Block Series 1 6L6 Amp Power Supply kawasaki99 Tubes / Valves 4 17th December 2010 06:17 PM
Series power amps using a floating power supply rtarbell Solid State 6 25th February 2006 08:18 PM
power supply: shunt or series?? AudioGeek Power Supplies 34 25th July 2004 02:02 AM
Series Caps in Power supply Jonathan M Solid State 14 11th April 2003 06:49 AM
