#11 | |
R16 measures 25.28k Ohms R17 measures 24.82k Ohms R18 measures 24.09k Ohms R11 measures 198.0k Ohms R13 measures 351.8k Ohms R9 measures 329.3k Ohms The expected -300V lines measures -292.2V (measured from cathode of Z10 to anode of Z1). Because it was low, I measured Z6-Z10, which gave me a result of -143.7V Would replacing the resistors and zeners with newer, identically spec'd components be the next step? |
#12 | |
#13 |
Hey guys, just wanted to share the good news: I finally replaced the resistors and the tube (I just had another 6AU6 tube lying around and thought of giving it a shot) and that did the trick! I now have a fully functional tube power supply for the cost of a few 3W resistors. Thanks for all your help!
#14 |
Great to hear. Which resistors ?
#15 |
#16 |
| OD3 150V tube regulator | Bengali | Tubes / Valves | 3 | 13th November 2012 06:28 PM |
| Getting down to a regulated 150V | AudioFox | Power Supplies | 17 | 11th January 2011 11:01 AM |
| 150v Mosfet @ 146v? | theAnonymous1 | Class D | 12 | 16th December 2008 02:57 AM |
| 150V plate output tubes | engels | Tubes / Valves | 10 | 10th July 2007 05:01 AM |
