wrong voltage 7905?
wrong voltage 7905?
Old 19th January 2013, 10:38 AM   #1
hyperion007 is offline hyperion007  Sweden
Default wrong voltage 7905?
I need some help figuring this out and YES I am a noob
The problem is that the voltage I am seeing after the 7905 is about -8.5V when it clearly should be -5V
I have tried several 7905's with the same results.
I do get +5V from the 7805.
and I get -12V and +12V directly after the rectifier
I have used the same 7805 and 7905 with a ATX power supply with +/-12V and that works great.
I have attached the schematic.
Any ideas would be great.
Thanks.
Old 19th January 2013, 10:40 AM   #2
R.I.P.
minimum current stated in datasheet?
another unhelpful post?
regards Andrew T.
Old 19th January 2013, 11:10 AM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Thanks.
IIRC 7805 and 7905 have different pinouts. Did you verify?
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 19th January 2013, 11:21 AM   #4
madtecchy is offline madtecchy  England
Hi jan he seems to be aware of it .. That is if he has constructed to the posted scem..
Mark
Old 19th January 2013, 11:26 AM   #5
Yes I am aware of the different pinouts and yes I did make the schematic.
please explain minimum current because I can't find it in the datasheet. The thing that puzzles me is that it worked with nothing connected except my multimeter when I use the ATX power supply.
Old 19th January 2013, 11:27 AM   #6
Chris Daly is offline Chris Daly  Australia
7905 TO220 case metal is Vin, is the case of the 7905 touching another part of circuit, or is it isolated ? Are you using TO92 TO220 or TO3 ?
Old 19th January 2013, 12:08 PM   #7
I am using TO-220
What is that about the case being Vin? See attachment.
And no, the 7905 is in a breadboard and no other component is touching the case.
Old 19th January 2013, 12:13 PM   #8
Mooly's Avatar
wrong voltage 7905?
Try two inverse connected diodes across the regulators and maybe two from each rail to ground. Sometimes different charge rates of the various caps can reverse bias a reg for a millisecond or so and cause a latch up.
Old 19th January 2013, 12:18 PM   #9
impuls is offline impuls  Yugoslavia
hyperion007, AndrewT gave You the answer. Read datasheet.
Old 19th January 2013, 12:24 PM   #10
Mooly's Avatar
wrong voltage 7905?
Not at all... I've come across "minimum currents" on regulators before.
wrong voltage 7905?Hide this!Advertise here!
7905 bypass current herryawan Power Supplies 5 29th May 2012 06:22 AM
Why high voltage Fets when low voltage types gives less distortion? Circlomanen Pass Labs 21 9th December 2009 09:43 PM
Using a zener diode as voltage reference with variable voltage regulators ginetto61 Power Supplies 14 20th September 2009 01:55 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
