trying to get 15-0-15 - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th January 2013, 12:40 AM   #11
just another
wintermute's Avatar
Hi Bradford336, after wiring the transformer up with four and five together. check that you get 34V between 3 and 6 (you should).
*If* you get zero volts then the secondaries are wired out of phase and you should try 4-6 for the zero volts. then you should get 34V between 3 and 5.
assuming that the first is correct, you run 3 and 6 to your AC in on your board, and the junction between 4 and 5 to the zero volts on your board. Aas your board only has two AC in's and a zero volts I'm reasonably confident that that is how it is configured. If it was running dual bridges it would be wired differently.
Tony.
Any intelligence I may appear to have is purely artificial!
planet10 needs your help: Let's help Ruth and Dave
Anyone have info, comments, experience with the RE XXX 15 VS TC Sounds LMS-r 15? SpinMonster Subwoofers 7 2nd May 2012 03:52 PM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
FS: pair Wharfedale 15 inch -W/15/CS(Cloth Surround- 1955/56) $100 MichaelPublic Swap Meet 3 10th June 2009 06:49 AM
15" Immortal Subwoofer awis-15 bil Car Audio 0 30th May 2006 07:46 PM
For Sale: One TC Sounds HE-15 cube (similar to Stryke Power 15) Phloodpants Swap Meet 1 7th May 2001 10:44 PM
Copyright 1999-2017 diyAudio
