Electrolytic voltage rating
Old 18th January 2013, 09:26 AM   #1
alibear is offline alibear  United Kingdom
alibear's Avatar
Default Electrolytic voltage rating
Hi all, I have 8 new Epcos 47000microfarad 40V capacitors that I would like to use in a Power supply for a class A amplifier. The transformer has a secondary of 25 -0- 25 and when rectified under no load is about 37V dropping to 35V when loaded with 1.6 amp bias of the amplifier.
My question is : is it safe to use 40V rated capacitors, or am I sailing too close to the wind.
Thanks for your help
Alan
Old 18th January 2013, 10:15 AM   #2
Mooly's Avatar
That's acceptable although you also need to allow for the mains being at the top end of its tolerance which is around 253 volts AC in the UK. If the 37 volts you measure is with the mains at the lower end (around 216) then they won't be suitable.
Old 18th January 2013, 10:36 AM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Mooly, your wording their might be slightly confusing.
The 40V electrolytics will be FINE if the 37V measured is when the mains voltage is at its maximum. However, if it is measured when the mains voltage is at the low end of its tolerance - ie 216V - then the voltage will exceed 40V when the mains voltage rises.
Old 18th January 2013, 10:42 AM   #4
R.I.P.
a 230:25+25Vac transformer is too high for 40Vdc capacitors when fed from the 240Vac UK supply.
I have posted the calculation many times before.The maximum off load voltage for a 7% regulation transformer will be about 41.3Vdc. Well over the 40V rating.
I have used up my quota of unhelpful posts, no more today.
regards Andrew T.
Old 18th January 2013, 11:09 AM   #5
Mooly's Avatar
I think the 37 volts dc that alibear measured is already off load and so is already a "worst case figure" regulation wise. That voltage can't go any higher for the applied mains voltage. It is just the mains voltage that was applied at the time of the measurement that is the unknown
Old 18th January 2013, 12:15 PM   #6
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
I think I know where Andrew is coming from, though my calculations say that with 7% regulation (unless I'm calculating wrongly) I get around 39.9V
This is based on 25V being the nominal output at full load.
multiply 25V by 1.414. Multiply by 1.07 (for 7% regulation) and then by 1.054 (for the 13V extra that the mains may actually be)... that for me comes out at 39.9V (with 10% regulation I get almost 41V). perhaps I have forgotten how to take regulation into account.....
However as this is going to be a class A amp the current draw will be constant, so the regulation of the transformer can probably be taken out of the equation (assuming that the load is always on, and it is being driven close to it's VA rating). If you also take diode losses into account there should also be some loss there so the 1.414 multiplier is probably a bit generous.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 18th January 2013, 01:06 PM   #7
Manufacturers will sail that close to the wind to save money.
In the DIY World you would be better to err on the side of caution and go for the next voltage up which is normally 63V.
Depending on the cap manufacturer also depends on how conservative they were with their working voltage rating.
If you've got them already you will probably be OK. If you are buying new ones, go for the next voltage up.
Old 18th January 2013, 07:57 PM   #8
alibear's Avatar
Hi all, thanks very much for your replies, I deduce from them that I will probably be OK, but if the voltage on the caps could be reduced a little it would be better. As I said this supply is for a class A amplifier with a bias of between 1.6 and 1.7Amps, with 4 47000microfarad capacitors on each channel and one 25-0-25 300Va transformer for each channel. Are any of these suggestions suitable for reducing the voltage slightly:
1) Place a CL60 in series with the primary windings.
2)Use two bridges per transformer ( one for each secondary winding )
3) Place a low value resistor ( 1ohm ? ) between the bridge and capacitor
4) Place a low value resistor (1 ohm ? ) between the two capacitors that are on each rail to give me a CRC.
Will any one of these, or a combination, give me a reduction in voltage, obviously I do not want to do anything that will affect the quality of the amplifier.
Alan
Old 18th January 2013, 08:13 PM   #9
Elvee is offline Elvee  Belgium
Elvee's Avatar
Alan
Unless you made your measurements when your mains voltage was at the extreme low of the tolerance bars, I think you'd better leave everything as it is.
Your class A amp will draw current, no matters what happens, and even if a fuse blows, you will still be within limits (and probably react rather swiftly if you have no sound).
Any additional impedance you add anywhere will adversely effect the quality and reduce the available power.
As long as you stay within limits (with some margins) with quality caps, you risk nothing.
As far as I know, Epcos is the inheritor of the Siemens brand, and if they keep up with the same quality standards, you should have no trouble at all (even if your mains happens to be 20% higher, but I shouldn't say that, I risk encouraging irresponsible behavior)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 19th January 2013, 02:10 AM   #10
metalsculptor is offline metalsculptor  Australia
Epcos capacitors are widely used in the industrial field. If the 40V is working voltage the makers are well aware of mains and load variations then they will have taken that into account when establishing the rating. Everything in engineering has tolerances. That is why there are working and absolute maximum ratings.
You should be consulting the makers datasheet first, then asking how to interpret the ratings if necessary.
Another vote for leave it as is.
Electrolytic voltage ratingHide this!Advertise here!
Replacing electrolytic caps in crossovers - what voltage rating to use? Ruach Multi-Way 37 16th December 2016 09:07 AM
Resistor Voltage Rating kroto Parts 11 29th April 2010 01:24 PM
High Voltage Electrolytic Caps Bengali Parts 4 19th October 2007 07:45 AM
Exceeding electrolytic cap rating Pierre Power Supplies 22 16th September 2007 10:53 AM
relay voltage rating jarthel Parts 41 24th August 2006 03:43 AM
