#41 |
just another
I'm not an engineer, but I would like to know how you calculated his input voltage when you do not know the regulation of the transformer or it's va rating
Tony. |
#42 |
Forget it...
He has 50V capacitors now. With his 50V capacitors he will now survive 357VAC over voltage to his transformer. :-) Which is nice... :-) |
#43 | |
but would the caps ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#44 |
...And 375V with his amplifier connected...
Which is also - nice... :-) OK, bad joke. Im an evil, evil little man... |
#45 |
The mind boggles how to make mountain out of a mole hill the OP stated the output voltage under the normal running conditions at 35V even in the unlikely event that it was measured at supply -6% the worst case would be supply +10 to get 40.9V well inside the the absolute maximum rating of the capacitor.
While I would have used 50Vdevices because they are common if I had 40V devices on hand I would have used them also. I and I would have done the trivial thing of measuring the mains voltage at which the output voltage was measured which could well have been 240V and saved 5 pages of speculation. |
#46 |
hey, there's always something to learn
![]() regarding cap lifetime mentioned to might being shortened by the possible small over voltage since he already have them, the weird thing is, his caps would actually last much shorter if put back on the shelf |
| Resistor Voltage Rating | kroto | Parts | 11 | 29th April 2010 01:24 PM |
| High Voltage Electrolytic Caps | Bengali | Parts | 4 | 19th October 2007 07:45 AM |
| Exceeding electrolytic cap rating | Pierre | Power Supplies | 22 | 16th September 2007 10:53 AM |
| relay voltage rating | jarthel | Parts | 41 | 24th August 2006 03:43 AM |
| Replacing electrolytic caps in crossovers - what voltage rating to use? | Ruach | Multi-Way | 6 | 30th November 2005 07:30 PM |
