Hi, for a project i need to make a protection circuit.
Input can be from 1 to 65 70 volt.
Output must be on from 20.5 to 56.5 ( with mosfet always in saturation or closed, not in half state) taking out lower voltages and higher voltages... a voltage band pass gate with 1 ampere max.
I played with mosfet and zener, the way is right.
Some idea about a simple des for it ? thank!
I think this is what are you looking. Check this link:Voltage Comparator Switch
- Power Supplies
- voltage gate circuit... help!
