Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th January 2013, 11:32 PM   #1
Default Amplifier usefulness
Hey guys I pulled these power transformers from an old HP SHF signal generatorClick the image to open in full size.
Can anyone suggest an amplifier that would would be possible with these guys?
I really don't know where to begin from a design point of view. Any input would be appreciated.
Thanks, JKJr
Old 13th January 2013, 12:30 AM   #2
DUG is offline DUG  Canada
Bottom could be used for a headphone amp...series the windings to get a xxVACct.
You have 4 x 6.3V and 2 x 5V. Max current would be of the lowest value. (bottom 6.3V is 1.?A?)
+/-12V reg for final stage and +/-17V for the driver stage...both regulated.
The top one could be used (carefully) for a supply for ESL biasing.
Doug We are all learning...we can all help
Old 13th January 2013, 04:58 AM   #3
You might be able to use the bottom one by itself for a ESL headphone amp.
Use a class D stereo amp from the low voltage supplies and drive push-pull tube output transformers and the Bias could be generated by the 375VAC winding.
Old 13th January 2013, 01:49 PM   #4
DF96 is offline DF96  England
Could be ideal for building an oscilloscope, or anything else which has lots of small signal valves and needs a little current at rather high voltage too.
Old 13th January 2013, 02:27 PM   #5
kevinkr's Avatar
Put them on eBay and get a transformer that suits the project you have in mind. These would be ideal for a scope project or similar, available supply currents are in line with what is required for low power tube gear and filament heating.
The filament transformer in particular may be extremely useful to someone into building tube electronics.
I'm also thinking these transformers might have come out of one of the old big ticket HP RF generators unfortunately. Shame to kill test gear that might be useful to someone else.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Motional feedback amplifier based on Philips 40 wats amplifier 1970s sanbadgujar Solid State 8 19th May 2013 01:31 PM
converting PA amplifier into symetrical class A son of Zen amplifier muddasirwaheedmalik Pass Labs 5 16th October 2012 04:01 PM
Usefulness of 6X8 tube? korneluk Tubes / Valves 22 21st April 2010 05:54 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
THD Usefulness Thread = Son of Opti-MOS ? mefinnis Solid State 11 13th March 2001 02:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
