Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th January 2013, 09:40 PM   #1
abcdmku is offline abcdmku  United States
Default ~20V AC threw ~100V AC to 12 V AC
So I am working on an interesting project, but not ready to say all the info on it yet. But I'm looking for an AC to AC step down converter that will take an input as low as 20 volts +/- 15 volts and as high as 100 volts +/- 15 volts but will have an output of 12 volt AC [an output of 12 volts DC will work too]. The current I would be working with is about 20 amps, but 10 amps will work too. An assembled product is preferred, but if there's only schematics that will be fine.
Old 12th January 2013, 09:48 PM   #2
I just realized I said threw. I meant through*
Old 12th January 2013, 10:14 PM   #3
Send a message via AIM to DigitalJunkie
SMPS. DC-DC converter,with an input range to cover your needs,and a (regulated?) 12V output.
20V with a tolerance of +/-15V? So,as low as 5V?
A supply with an input range of 5V-120V isn't going to be easy to find,or build.
It'll have to be some kind of buck-boost supply.
Old 12th January 2013, 10:30 PM   #4
DUG is online now DUG  Canada
"The current I would be working with is about 20 amps, but 10 amps will work too."
Is that for the supply or the load?
Doug We are all learning...we can all help
Old 12th January 2013, 11:38 PM   #5
DUG: that is for the load.
DigitalJunkie: I'm looking for anything with a range as large as 5V-120V or as small as 35V-85V, sorry I should have worded that better.
Old 13th January 2013, 12:19 AM   #6
35V-85V would not be difficult. PWM step down.
5V-120V would be very complicated. Dynamic full range or static conditions?
I'm still not sure of what you really want.
Old 13th January 2013, 03:06 AM   #7
35v-85v would be good enough. I would need it to be dynamic for the supply, and static for the load at 12v. Is there anything out there that is already near that range being sold, that would make things easier.
Old 13th January 2013, 04:30 AM   #8
As DigitalJunkie posted in #3, rectify to DC and then used smps to down convert
Did a digi-key search and found 2 that would work (dc-dc), but of course neither are in stock.
FK1301-7R Power-One | FK1301-7R-ND | DigiKey
CK1301-7R Power-One | CK1301-7R-ND | DigiKey
only $5400 ea
Is that what you were looking for?
Old 13th January 2013, 05:37 AM   #9
Well that is slightly pricy.. but I found this:
"Name: DC~DC Step Down Voltage Converter
Model: EZ-DCSD8012-20
Input Voltage: 30V ~ 80V DC
Idle Output Voltage: 14V ± 5% V DC
Load Output Voltage: 12V ± 0.5 V DC
Overvoltage Output Protection: 17 V DC
Rated Output Current: 20A
Rated Power: 240W"
It's $70
Old 13th January 2013, 03:04 PM   #10
yea, cheaper when non-isolated
If that meets your need then that is great.
Need schematic for AC to DC converter (12V AC in to 12-18V DC out) maurycy Power Supplies 6 6th January 2012 08:27 PM
Mesure DC in AC outlets Cant find what is making noise in my AC 30CCX Help!!! !!! Ulisez Power Supplies 13 23rd November 2010 06:42 AM
WTB: Analog AC Ammeter - AC Voltmeter - Panel Mount dBfreak Swap Meet 1 16th March 2007 10:41 PM
PS question- Need to get 20V AC from 60V AC - w/o Trafo lgreen Pass Labs 9 2nd January 2004 10:31 AM
HUBBELL IG3800 clones? AC sockets /AC wire jasonruiz Parts 5 25th April 2003 10:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
