#11 |
I see no switch/relay or sensing circuit in the posted schematic, so I assume this is done on AC side of the rectifier, i e a transformer with two windings. That would of course prevent any voltage dip, given that the rectifier caps are large enough.
listen! Can you hear that ... |
#12 | |||
If you make a PCB, it is probably a good idea to include all the options, to maximize its flexibility and fully benefit of its versatility. I will redraw a suitable schematic. Quote:
I understand that this can lead to some confusion, especially since the "general" circuit is so much like the application example. That's no coincidence of course: when I designed the circuit, I had in mind that particular application. I first had to build my prototype as a stand alone supply, to make sure it was proper and healthy before I could blend it with the existing circuits, otherwise, in case of problems I wouldn't have any reference point and would have had diificulty tracing the origin of problems. As I said above, I will post a more general schematic, including all the options and mods. At present, all the correctives except for Q6 apply to the particular issues arising from grafting the circuit onto an existing supply. Quote:
The switchover time is short enough to allow the filter cap to ride through, as rikkitikkitavi rightly remarks:
#13 |
Here is the schematic, updated with all the options I could think of.
You can pick and choose what you like best.
#14 |
Hey
Can this schematic work for higher voltage? |
#15 |
I am pretty sure it can: I have successfully simulated some examples, see above, BUT simulation is no substitute for reality, especially in the high voltage field.
I am 99.9% confident I could have a high voltage version working, but realistically the working sim schematic would probably need some tweaking and adaptations to be really safe and effective in reality. I will probably test a HV version in the coming days or weeks (or months). In the mean time, if you have sufficient experience with HV, you can try it (carefully) for yourself.
#16 |
I made a quick and dirty breadboard test of this HV version:
![]() It worked immediately (except I had connected the 330µF/400V filter cap in reverse and had a narrow escape). There are some differences with the schematic: transistor types were different, with a 2SC2922 as a ballast for example, but that is secondary. In order to reduce the quiescent dissipation, I also doubled the values of all DC-affected resistors: for example, R9 & 26 became 6.8K, the 680 ohm became 1.2K, the voltage and current pots became 2.2K and 1K, etc. That is acceptable since the output current is half of the low-voltage version. In order to keep some advance warning with the current limit, I changed D4 for a 5V6, and the optimum output resistance compensation R19 was 22K, but this did not affect the functionnality of the supply, and at all times it was stable both in current and voltage modes, despite the breadboarding. Thus, it looks pretty safe. For this kind of voltage, it essential to keep in mind the SOA limits of the pass element(s). Neglecting that will certaily result in molten silicon. I also dropped in a 2SK794 NMOS as a replacement for Q1, and it worked transparently, with just R1 raised to 680ohm. All the parameters remained unchanged, including the compensation resistor. I even played the sorcerer's apprentice by removing completely the compensations C3 and C5, and it remained stable, both in voltage and current, but I don't recommend it, as they look necessary in the sim.
#17 |
ELvee, I looked over your post 13 were you posted your latest schematic. I noticed that you left several values off of the schematic. Was this an over sight or are we supposed to calculate these for our specific use?
Components with no values. R32, R28, R26, R29, C8, R17, R20, D1, C7, R21, R30, R31, C10. Should Zero adjust R and I Adj, be a resistor or a POT? Thanks |
#18 | ||
For example, with a higher voltage version, it is convenient to split the dropping resistors in two or three to spread dissipation, and it is possible to add supplementary filtering in the middle, etc. You pick and choose want you want, and calculate it accordingly. The latest 150V 1A example uses some of these options. Quote:
#19 |
hey.
If anyone need shemaich and pcb in eagle. |
#20 |
Very nice, thanks, I am sure it will help the community.
| A HV lab supply | triode_al | Equipment & Tools | 3 | 1st June 2012 11:47 AM |
| HV lab supply | hidnplayr | Power Supplies | 1 | 17th February 2010 12:25 PM |
| Lab supply repair help | shzmm | Power Supplies | 3 | 9th January 2010 07:49 PM |
| GC with lab supply | Eric Weitzman | Chip Amps | 1 | 5th March 2005 03:32 PM |
| diy lab supply | jazz | Solid State | 9 | 20th January 2005 09:28 PM |
