Soft Start w Mute for LME49xxx Drivers
Old 10th January 2013, 08:15 PM   #1
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Soft Start w Mute for LME49xxx Drivers
I figured that I could do it a little more simply than TI's Application Note AN-1849 with a depletion mosfet instead of the plethora of zeners:
The LND150 is a pretty inexpensive TO-92 part available from Mouser. Troy used a micro-wave oven relay. The PC mount seems to be ALE1PB48 with contacts rated at 16A. The relay takes about 5 mA to click over.
The circuit will mute as soon as the power switches off, thus it is important to have bleeders on the filter caps.
Regrettably, TI chooses to eliminate the names of the authors of some of its application notes. Sounds like a 1950's re-education program to me.
Old 11th January 2013, 03:03 AM   #2
jackinnj's Avatar
Looks like this:
Old 12th January 2013, 02:12 PM   #3
jackinnj's Avatar
The chips like the LME8930 require about 250uA on the mute pin to go, that leaves about a milli for the LED -- so I modified it so you can use either a LND150 or DN2540:
R2 will have to change if you use the bigger depletion MOSFET.
Old 12th January 2013, 03:20 PM   #4
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
PCB does not look that complex.
You could do it single sided easily...
Soft Start w Mute for LME49xxx DriversHide this!Advertise here!
soft start help pmchoong Power Supplies 18 14th January 2011 07:50 PM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 02:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 10:23 PM
Tripath sleep/mute start up delay BWRX Class D 1 25th September 2005 09:45 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 04:32 PM
Copyright ©1999-2017 diyAudio
