#11 |
To get a clearer picture can you please:
Give all component values, Measure DC and AC voltages on all regulator pins, Measure the current from reg-out to heater wiring when volts are low, Test the circuit with a dummy load 22 Ohms 5W or a dial lamp 7V 0.3A. The 6922 is rated at 0.3A. Test the heater wiring with a bench supply, a 6V battery, 5V wall wart, or a simple heater transformer. Use a fuse! Just a thought: 1.24V is the typical Vreg of the LM338. |
#12 | |
If the DC is powering a Class B/AB power amp then you can get most of that factor back again because of the duty cycle of real music. Thus a 50VA transformer can (very roughly!) just about power a 50W amp (or 25W stereo). Heaters draw continuous current so you lose this advantage. |
#13 | |
Cheers! |
#14 |
250mW power, maybe 200V voltage? Should not be a problem for a 6.3V supply.
#15 |
With load, the waveform to the bridge rectifier is about 9.5 volts p-p. The voltage at the input of the power regulator is about 10.4 volts DC. The waveform pretty flat with some noise at the 1mV setting. This measurements were taken with just the 6922 plugged in. With a good 10volts supply entering the Lm338K, I am beginning to suspect the power regulator is not set up correctly. The circuit was built as per the following schematic. The bottom section is of course the heater section that's causing grief. Cheers! |
#16 |
Sorry I had split my reply up. This is the waveform of the AC input at the bridge rectifier with load. I am getting a good 10.4 volts input at the power regulator. Cheers! |
#17 |
Case of LM338K is out, but In and adj can easily be interchanged.
#18 | |
![]() The other resistor can sometimes need a half watt or more, but not at 6.3V I'm wondering if your heat sink/case of regulator, is shorting with something |
#19 | |
Try applying full power to the circuit then switching on a heater load. The transient load from a cold heater can be determined by measuring the cold resistance, the valve datasheet may mention it as well. There is a simple soft start circuit on the TI lm138 datasheet, this might be another option if the variac is causing trouble Just check you have connected the 338K the right way |
#20 |
Gents,
After a good summer holiday, a fresh re-look into the circuit revealed what was wrong. Thee feedback resistors were built into a small PCB that was mounted onto the voltage setting terminal of the LM338K. A wire was to provide voltage from the output of the LM338K back to this circuit. However, due to a fault in connection, no voltage was flowing back from the output to the resistor/trimpot network. Re-did the connection and the circuit came up beautifully. Thanks every one for the input! |
| Permissable voltage sag? | johnr66 | Power Supplies | 14 | 1st May 2011 06:55 PM |
| sudden voltage sag | forcijo | Car Audio | 12 | 23rd July 2010 02:43 AM |
| B+ Voltage sag for AB1 PP | boywonder | Tubes / Valves | 34 | 26th January 2010 01:16 AM |
| Distortion from heater sag? | hihopes | Tubes / Valves | 33 | 7th October 2007 05:33 PM |
| Voltage sag | JonnySwitchblade | Solid State | 6 | 8th July 2007 10:20 AM |
