Help with main transformer specs
I'm looking at this schematic to power a parallel se 300b monoblock.
Please verify the specs for the mains tranformer I have come up with.
400v for parallel 300b and one 6sh7:
300b draws about 100mA, 6sh7 about 10mA
300b heaters draws max 1.5A.
5u4GB draws 3A
6sh7 heaters draw 0.3A
So with some margin that would be:
400v-0-400v @ 300mA for B+
2.5v-0-2.5v @ 4A for 5u4GB heaters
3.1v-0-3.1v @ 1A for 6sh7 heaters
2x 5v-0 @ 3A for 300b heaters
Does that seem right? Any under/over -rating?
Thanks in advance
Joined 2010
400 - 0 - 400, with a cap input, is going to give you approx 560 volts before the losses of the 5U4. Spec sheet for the 5U4 says a loss of 50 volts/plate @ 275 ma /plate. Your draw is under 200 ma total, so ball park loss in the 5U4 maybe 50 volts? That would give you 560 - 50 volts = 510 to 500 volts. If I'm right, you'll still have a bunch of volts to drop.
Seems I was a little premature with the schematic, ignore.
A more general question:
Do you spec a transformer purely on the current drawn from the tubes, or are there other things to consider?
So if I want a winding that can power 2 300b's, can I just say '300b draws max 100mA so i need a 2x100mA = 200mA rating on that winding'?
Is there a rule of thumb as for what margins to apply?
