diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   toroidal transformer wire identification! (http://www.diyaudio.com/forums/power-supplies/227060-toroidal-transformer-wire-identification.html)
dataplex 4th January 2013 10:56 PM
hello
i am making a power supply for my LM1876 chip amp.
here is the schematic im using:
http://i85.servimg.com/u/f85/13/75/87/43/psu113.jpg
the transformer i have is wired like this (according to the datasheet)
https://www1.elfa.se/data1/wwwroot/a...5612106-12.jpg
so.... which wire goes where to the bridge rectifier? the red/brown?
really dont want to fry it up, so any advice would be greatly appreciated!
thanks
úlfur
PedroDeMio 5th January 2013 02:55 AM
Join the red and brown, that's is your 0v, where you put the ground of capacitors
the green and blue goes for the rectifier
Mooly 5th January 2013 10:36 AM
If you are unsure then use a bulb tester (low wattage mains filament bulb) in series with the mains. That will limit current and enable you to check it safely. The bulb should be out (not lit) when its correct and all DC voltages will be correct too.
KatieandDad 5th January 2013 11:17 AM
1 Attachment(s)
A picture paints a thousand words.
dataplex 5th January 2013 02:59 PM
thanks for your replies!
alas, i hooked it up like you suggested - and POOF! - my LM1876 chip blew up. i have no clue what could have gone wrong.
i am using this schematic;
http://i85.servimg.com/u/f85/13/75/87/43/schema15.jpg
any thoughts?
KatieandDad 5th January 2013 03:12 PM
Try measuring the DC voltages from the power supply. Just check that you do have +/- 25V with respect to 0V.
Have you got bridge rectifier the right way around? The LM1876 would certainly fry if you inadvertently connect + to - and - to +.
KatieandDad 5th January 2013 03:24 PM
If all is well just recheck your soldering very carefully - look for any shorts.
Also check your speakers and their cabling for shorts.
Marra 5th January 2013 03:26 PM
As Mooly recommended use a bulb tester. One has saved my *** on a few occasions.
Mooly 5th January 2013 04:28 PM
You're going to have to replace the chip and power it up with the bulb tester to prevent damage. And NO speakers connected either.
I see the diagram doesn't show a zobel network... very unusual... I would certainly add one. Say 6.8 ohm and a 0.1uf cap from the output to ground.
dataplex 5th January 2013 05:34 PM
just replaced the chip... now nothing happens at all... must have fried something else on the board too.
i guess it's back to the drawing board...
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
