Power Transformer size influence on preamp sound.
Old 4th January 2013, 05:28 PM   #31
On Hiatus
SY's Avatar
Those are sucky sommeliers. Anyone with an MS or MW (or even someone juding at OC or Cal State Fair) will have passed a blind tasting screen.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th January 2013, 06:41 PM   #32
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Originally Posted by Cobra2 View Post
External...
(C-R-C-R-C- filtered)
Ok Cobra then that should be fine. But you have no regulator ? I wonder why the difference occur. I prefer E I or Rcore instead off toroid.
Old 4th January 2013, 07:00 PM   #33
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Power Transformer size influence on preamp sound. Power Transformer size influence on preamp sound.
And LM317/337 regulated...
Even "so far away" (~1,5m, +filters & regs) from the audio-circuit...there was a change.
(The C-R-C in external box, C-R-C + regs in riaa-box - C=10 000uF/R=6-8 ohm)
Arne K
Don't believe everything you think...
Old 4th January 2013, 09:08 PM   #34
Default Oh my god.
317 og 337 do not belong in hifi.
Old 4th January 2013, 09:31 PM   #35
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Blanket statements like this will get the engineering team after you for a change
Old 4th January 2013, 09:34 PM   #36
analog_sa's Avatar
Originally Posted by SY View Post
I'm using an Echo Audiofire 2 and have no problem making the walls flex.
Big deal. I've seen those american cardboard houses on the telly. Anything will flex them walls
Old 4th January 2013, 09:59 PM   #37
Yes I know but I am sure about this.
Power Transformer size influence on preamp sound.Hide this!Advertise here!
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 05:12 PM
Influence of power amplifier output coil to frequency response PMA Solid State 22 6th May 2011 08:17 AM
Which parameter of the filtering caps do influence the sound of a gainclone??? Leolabs Chip Amps 34 15th September 2007 05:04 PM
Influence of RIAA impedance value on sound Rtop84 Analogue Source 8 19th April 2006 03:08 PM
