Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th January 2013, 08:57 AM   #11
sofaspud's Avatar
Just to add... VA is not equal to watts. VA is a measure of apparent power in AC circuits.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th January 2013, 10:02 AM   #12
DF96 is offline DF96  England
Some people expect to see (or read about) unreasonably huge transformers/capacitors. In order to ease the extraction of money from such people you have to provide them with what they expect.
Old 4th January 2013, 10:48 AM   #13
Robert Kesh's Avatar
We're talking preamp here. Overrating is a process of diminishing returns. 100VA is already overated for pretty much any preamp. So 200VA won't make any improvement.
Old 4th January 2013, 12:02 PM   #14
Thank you ! And more capacity on regulators will compensate for a smaller transformer ?
Old 4th January 2013, 12:18 PM   #15
analog_sa's Avatar
It won't. More capacitance will present a heavier load for both transformers and rectifiers. Results are unpredictable at best.
There may be some science explaining the optimum ratio between power, current capacity, impedance and diode ringing but it's far from clear. Nothing gets you results as fast as comparing several trafos and various amounts of capacitance with your own ears feeding the preamp/dac in question.
It may turn out you really cannot hear the difference between a 10 and a 100VA transformer
Old 4th January 2013, 12:25 PM   #16
I do not think I can hear difference if the transformer is bigger than what is needed. I can hear difference for everything else and capacity even on output off Shunt regulators. I know capacity for shunt regulators should be low. I prefer more than recommended.
Old 4th January 2013, 12:41 PM   #17
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Hi anybody have some exsperience with power transformers size influence on sound in a pre or dac ?
Yes. There is no difference.
If 100 VA is enough will 200 then be better ?
No.
100VA is overkill.
200VA is over overkill.
Smashing an ant with a 20Kg hammer is the same as smashing it with a 10Kg one.
Old 4th January 2013, 02:11 PM   #18
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Yes. There is a difference. I have in several projects used/ended up with very oversized trafo(s). And not only me could hear the difference....
In my last riaa, I used 300VA, 50VA would been good...but did not sound as good.
Arne K
Ars longa, vita brevis
Old 4th January 2013, 02:14 PM   #19
Possibly the extra weight damped a chassis resonance?
Old 4th January 2013, 02:42 PM   #20
Yes yes yes It is what I believe . How was your supply Cobra ?
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
Influence of power amplifier output coil to frequency response PMA Solid State 22 6th May 2011 07:17 AM
Which parameter of the filtering caps do influence the sound of a gainclone??? Leolabs Chip Amps 34 15th September 2007 04:04 PM
Influence of RIAA impedance value on sound Uchi Deshi Analogue Source 8 19th April 2006 02:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
