Help with transformers
Old 1st January 2013, 06:33 AM   #11
DUG is offline DUG  Canada
There is another reason.
Here is an example.
You have 16Vp from either a half wave or full wave rectifier.
You need 2V "headroom" on a 12V regulator at 1A (14V min)
With a full wave rectifier the capacitor only needs to be 3500uF and gets recharged at twice the line frequency rate. During the time this value of capacitor needs to be recharged the peak diode (and transformer) current is about 20A.
With a half wave rectifier the capacitor needs to be 7700uF and gets recharged at the line frequency rate. During the time this value of capacitor needs to be recharged the peak diode (and transformer) current is about 32A.
The capacitor needs to be bigger to supply the charge to the regulator for a longer period of time. Slightly longer than twice as long so slightly more than twice as large.
The larger the capacitor, the more current it takes to recharge it in the same amount of time.
Hope that helps explain what is happening and why half wave rectification is rarely used.
It is used more with lower current applications. IMO
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 1st January 2013, 07:28 AM   #12
clocktower is offline clocktower  United Kingdom
Banned
Here is an example.
Very nice...
Old 1st January 2013, 01:49 PM   #13
paulb is offline paulb  Canada
Yes, so more filtering required and bigger peak currents. Still, this is the simplest solution to the problem and likely to be suitable.
When the OP asked how to use an existing transformer for a particular application, an answer of "get a different one" isn't really being all that helpful...
Old 2nd January 2013, 03:46 AM   #14
bear is offline bear
expert in tautology
bear's Avatar
kinda depends on what he is powering, doesn't it?
since low VA transformers are not expensive, i would go for it.
and high VA applications don't usually go well with half wave - and more caps cost money
too... so there is a balance to be found.
Maybe the OP might say what he is going to run with it?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 4th January 2013, 04:41 PM   #15
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
NigelWright got it exactly correct: Use of a half-wave voltage-doubler is the cheap-n-dirty way to get the voltages being looked for, -21 : 0 : +21 volts (before correction for peak-over-RMS)
NOTE though - it is definitely half-wave rectification, so the capacitors should be rather large to hold enough juice between waves. And also beware - BOTH the positive and the negative supply rails need independent regulators. And beware - that regulators that are complimentary are often happy to short the whole damned thing out if attached to the same heat sink.
GoatGuy
Help with transformersHide this!Advertise here!
Making CT transformers from two transformers infernal Parts 1 14th July 2011 08:42 AM
transformers JozzaG Power Supplies 0 4th February 2010 08:57 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Why Transformers? guitargully Everything Else 3 16th April 2004 06:19 AM
