Grounding of a custom power supply
Old 30th December 2012, 08:50 PM   #1
michouthefirst is offline michouthefirst  Canada
Default Grounding of a custom power supply
I am experiencing with power supplies and I am wondering how does one wire the supply for grounding. As I would like to see what is happening with an oscilloscope and there is always a voltage present between the probe ground and any terminal of the transformer, the fuse blows up.
Would someone be kind enough to point me to information answering the following questions:
- Do I connect the sector ground to the chassis?
- Do I connect the center tap of the secondary (for dual voltage power supply, for op amp polarization) to the chassis too?
Thank you,
Michel
Old 30th December 2012, 09:51 PM   #2
NissanSR20Man is offline NissanSR20Man
Xfmr sec neutral/center tap should go to the chassis ground/mains earth/safety earth what ever you want to call it.
See here for how to ground...understanding star grounding
And here...Transformer grounding questions
The scope probe should be on the hot, the probe ground the earth always. Never use the probe ground to measure floating / energized circuits. You can use the ground for measuring if using a differential probe or a battery operated scope. I doubt you have either. The fuse is blowing due to you shorting through the probe ground clip. It is connected to earth on the scope it self. The ground pin on the mains plug.
Old 31st December 2012, 03:31 PM   #3
Thanks for the info and the links. This helps
Grounding of a custom power supplyHide this!Advertise here!
Grounding for an external power supply JVDM Chip Amps 7 15th April 2012 02:41 AM
Custom Power Supply for Audio Alchemy DDE 3.0 gto47 Digital Line Level 0 12th November 2011 09:03 PM
Grounding for Mixer and Bipolar Power Supply bbmonster Instruments and Amps 1 20th March 2009 07:59 AM
Outboard power supply grounding ? woody Power Supplies 5 3rd May 2008 09:24 PM
grounding & power supply questions timsch75 Chip Amps 2 15th January 2004 05:04 PM
