Power supply resistor matching
Old 5th January 2013, 07:35 AM   #21
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
or grid stoppers....i use carbon comps here, G1 and g2 and i do not even bother to match them....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 5th January 2013, 08:04 AM   #22
metalsculptor is offline metalsculptor  Australia
without a schematic it is difficult to assess the effect. For a differential pair, using unmatched resistors can reduce the PSRR of that stage. If the subsequent stages are single ended then it is unlikely that the effects of unmatched resistors will be noticed.
Old 5th January 2013, 08:10 AM   #23
TonyTecson's Avatar
i think that MGH has his head into tube amps, he has been asking these types of questions for as long as i can remember....
his questions are always too general so that a myriad of responses are the outcome....
i hope he has gotten over the OPT thread wherein he kinda got depressed....when shown the Dynaco transformer data sheets....
my recomendation to MGH is to search for the postings of PRR for starters, he will pick up a lot in those posts, no snake oil guaranteed....
Old 5th January 2013, 08:12 AM   #24
TonyTecson's Avatar
what i look for is in the finished amp, is it stable and quiet? no hum, no hiss......
Old 5th January 2013, 11:45 AM   #25
My responses were general and applicable to tube circuits, I know few DIY audio tube amp builders use differential pairs but they were used in instrumentation and professional audio toward the end of the tube era. Electrically there is little difference between a tube circuit and a FET circuit, especially those using depletion mode FETS.
Tube output transformers are certainly a challenge for a transformer designer.
Old 5th January 2013, 10:29 PM   #26
TonyTecson's Avatar
in a tube LTP splitter stage anode loads are deliberately mismatched.....in any case, understanding how a circuit functions is more important than matching resistors......knowing when and where is also just as important......
Power supply resistor matchingHide this!Advertise here!
Help finding matching power supply for Ivchikx Power Supplies 2 6th March 2011 04:59 AM
Audio note M2 power supply resistor value drobert Tubes / Valves 0 20th November 2007 10:01 AM
Resistor matching tip Nordic Parts 5 13th January 2007 05:19 PM
bleeder resistor for ZenV4 power supply; and ancllary matters Zapped Pass Labs 13 24th September 2003 04:02 AM
power supply for Mosfet matching russbryant Pass Labs 3 12th November 2002 08:04 PM
Copyright ©1999-2017 diyAudio
