Hello
greetings having assembled this smps its working but IC VIPER12A
should give 15.5 volts on connecting to pin 1 of IR2153 supply drops to 8 volts smps is being used with top ic 244 voltage does not drop and smps works can anyone help out
warm regards
andrew lebon
warm regards
andrew lebon
SMPS HELP
Hello
greetings viper 12A voltage dropping to 8 volts on connection to ir2153
taken 310 volts dc supply to viper ic input should i try connecting to ac 220volts using ultrafast diode and 10uf 450 volts cap
warm regards
andrew lebon
Hello
warm regards
andrew lebon
- Power Supplies
- smps
