Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th December 2012, 02:14 AM   #1
Einric is offline Einric  United States
Default MUR860 Full Bridge Rectifier
How would a full wave bridge rectifier made from naked MUR860's stack up against a standard 35A potted Full Wave Bridge Rectifier?
Old 18th December 2012, 02:39 AM   #2
Mur 860 is only good for 8 amps. If it's a high power 100 watts or more power amp with big 22,000 uf caps or more then you want higher current rated diodes
IR has some nice 25 amp hexfets ( and 60 amps). Harris, Fairchild, etc
Old 18th December 2012, 02:43 AM   #3
Triodethom's Avatar
There are some question before that can be answered . 1. how big is the current requirement . 2. how big the first cap. 3. What curcuit do you want to power.
Old 18th December 2012, 02:59 AM   #4
Well this will be for a Pass F4.
I will be using the DIY Audio pcb's and running about 1.5A of bias.
The first cap will be 2 15kuF in parallel followed by .11R then 3 15kuF in parallel.
Old 18th December 2012, 03:06 AM   #5
Someone had suggested I use Schottky Rectifiers instead of the MUR860.
Would something like this be more suitable?
Old 18th December 2012, 03:17 AM   #6
Triodethom's Avatar
try
STPS30100ST STPS30100ST STMicroelectronics | Mouser
That has a 100 volt version .
Old 18th December 2012, 03:21 AM   #7
I see that one also has two anodes that are electrically common.
And it's cheaper!
It just has a higher forward voltage drop.
Old 18th December 2012, 01:56 PM   #8
Triodethom's Avatar
for this 30a and keep your piv up and you are there as far as I can see then use good caps.
Old 18th December 2012, 11:14 PM   #9
I will be using Cornell Dubliner SLP 15000uF 25V 105deg. in a 2-R-3 per rail.
Old 19th December 2012, 12:30 AM   #10
Robert Kesh's Avatar
Isn't 25V a little too close to the supply voltage for comfort? Especially before the R.
Full Bridge Rectifier With Tubes Einric Tubes / Valves 9 1st December 2011 06:52 PM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
How much AC is usually let through a MUR860 rectifier bridge? bg4533 Power Supplies 9 12th April 2005 03:10 AM
Pcb for MUR860 (or some else TO220 diode), rectifier bridge peranders Swap Meet 14 17th September 2003 10:37 AM
Copyright ©1999-2013 diyAudio
