Audio Alchemy DDE V 3.0 question - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th December 2012, 04:43 PM   #1
Franz Gysi's Avatar
Default Audio Alchemy DDE V 3.0 question
Hello
Inside my Audio Alchemy DDE 3.0 DAC is this sub-circuit as regulated psu for the analogue part:
The opamps are supplied with heathsinks and they get very hot (guessed 70 to 80 degree celcius).
Why?
Old 20th December 2012, 02:48 PM   #2
Franz Gysi's Avatar
Default PSU for the analogue part of the circuit
I would be happy for any advice.
My Audio Alchemy DDE 3.0 DAC does often not power up correctly. One or the other channel does not play.
Now, I recognized the fault within the shown psu part.
Sometimes, the positive or the negative voltage fails during startup. When the output voltage is O.K. I measure 7.5V over the zener diodes. When the output voltage is not O.K., some 0.7V over the zeners.
All LED's are always lighting.
My questions:
- What could be the reason for this fault?
- Why are the opamps supplied with heathsinks, why do they get hot by design in this circuit?
Franz
Old 22nd December 2012, 11:00 AM   #3
Franz Gysi's Avatar
No answers here, so I looked in my theory books
This subcircuit isnt very good, same as LM7815/LM7915.
And I found this comment in Audio Alchemy (DDE V3.0)
But i've looked into the schematic I found on the Internet and the problem is a very very very and VERY unstable +/-15V stabilizer circuit.
It looks like this section was designed by a nono because you have luck when this circuit is working at starting up the system.
I’ve made some fast modifications and now the +/-15V section starts up AND is stable.
I'm thinking about chaning tis section complete by inserting a shunt-regulator.
Any idea, what could be the fast modification? Dont pull the voltage for the bias zener (D32/D37) from the output but from the input?
Franz
Old 22nd December 2012, 01:41 PM   #4
Franz Gysi's Avatar
Default I did it
My monologue
I repaired my Audio Alchemy DDE 3.0 DAC successfully, it is starting up now without problems!
As it seems to be a common problem with this devices, this posting could be helpful for other owners.
What I did:
Just removed the zener diodes and the 499R resistors on one side, joined it in the air and connected it with a 1k2 resistor to pin 4 or pin 8 of the opamp.
Before:
After mod:
Franz
/Edit
After posting this pictures, I remarked a loose piece of wire in the second picture, reopened the box and removed it. Good luck, isn't it?
Old 14th January 2013, 05:55 PM   #5
Franz Gysi's Avatar
An illustration of my modification (one channel only):
Old 14th January 2013, 08:32 PM   #6
Good move!
Now the +/- reference voltages are created from the unregulated input rather than the output. Clearly, there was a stability problem with this regulator and it had started to oscillate at a low frequency.
- Poetry2me
Audio Alchemy DDE v1.2 schematic? walker112 Digital Source 2 7th December 2015 02:20 AM
Looking for AUDIO ALCHEMY DDE v2.0 schematic olaychang Digital Line Level 1 22nd July 2011 10:57 AM
F/S Audio Alchemy DDE v3.0 rubicon Swap Meet 2 27th November 2010 06:32 PM
Schematic for Audio Alchemy DDE V1.0 Edlo Digital Source 0 31st October 2004 05:10 PM
problem with my audio alchemy DDE 3.0 dexter Digital Source 0 23rd February 2004 04:39 AM
Copyright 1999-2017 diyAudio
