Dx Supply, output adjustable, stabilized power supply
Old 11th October 2013, 08:19 PM   #181
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Mister Terry have you seen mister Carlos videos? he operate Dx Super A with AA batteries
I mean this does not mean that your are going to do it, he is just showing that Dx Super A can operate at that minimum supply voltage
Audio amp. powered by Triple A batteries - Amp. movido pilha - YouTube
I did it too with a small transformer and it even operates too meaning there is a lot options but fallow mister Carlos suggestions
Juan
audio fanatic only
Last edited by vargasmongo3435; 11th October 2013 at 08:28 PM. Reason: grammar error
Old 11th October 2013, 11:48 PM   #182
still4given is offline still4given  United States
still4given's Avatar
I just wondered because he said the power supply needed to be able to sustain a 10A load. I don't plan to be anywhere near that.
Thanks, Terry
Old 12th October 2013, 01:26 AM   #183
ohooo I see mister Terry the idea of the regulator is to keep a constant and steady power a reservoir when power is need it, I was checking a few minutes ago and the power consumption playing soft music is about 327mA (330mA) on the positive rail the regulator should be just right.
Juan
audio fanatic only
Old 24th October 2013, 08:00 AM   #184
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Juan Vargas new email adress is
juanvargasdiaz1970@yahoo.com
In this year, when Juanito born, i was already in the army.
Young Juanito.
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 24th October 2013, 04:14 PM   #185
Then in 2005 I join the Army later 2 deployments to Iraq, I never going to forget, thanks battle buddy
Juan
audio fanatic only
Old 20th November 2013, 11:02 AM   #186
Default Dx Supply is included in the package.... Juan have amplifier pcboards
And also power supply pcboards.
This is good to clarify.
Also the Dx Supply can be used together other amplifiers, the output voltage is adjustable.
regards,
Carlos
Old 23rd November 2013, 10:02 PM   #187
Hi Guys,
I have been using my DX Supply with an SKA GB150. I am using a 40-0-40VAC transformer and dialing it down to +/-50vDC rails. It is feeding both channels which are set to 250mA per rail each. I had fairly large heatsinks installed on the supply but they never even got warm to the touch. I wanted to reduce the size to make it easier to install in the case I am building for the SKA so I remove the heatsinks and just cut some pieces of 1/4" x 2-1/2" x 6" aluminum bar and attached them to the MJL21193(PNP) MJL21194(NPN) outputs. They still barely get warm to the touch even after prolonged playing. So I am curious, what does it take for the outputs to need large heatsinking, Class A?
Thanks, Terry
Old 23rd November 2013, 10:57 PM   #188
Ranchu32 is offline Ranchu32  Australia
Terry, try a sinewave into a dummy load at moderate to high power. If the pass transistors don't get warm/hot after 10 minutes I'd be suprised and suspect something amiss.
Old 23rd November 2013, 11:00 PM   #189
How do you play a sine wave through a power supply?
Old 23rd November 2013, 11:10 PM   #190
I'm suggesting you play a sinewave through the amplifier connected to the power supply to generate sufficient current draw through the pass transistors in your power supply. If you are playing music at normal levels through a medium power Class A/B amplifier, and the quiescent current in the normal range, then the average power draw is going to be low. If you want to see the pass transistors' heatsinks get hot to confirm proper operation, then play the music really really loud or drive the current into a dummy load.
Dx Supply, output adjustable, stabilized power supplyHide this!Advertise here!
Adjustable power supply questions rendisha Parts 28 10th June 2013 10:57 AM
Adjustable High Voltage Power Supply alfa88 Equipment & Tools 7 8th January 2012 12:33 PM
Adjustable Regulated B+ power supply question Captn Dave Power Supplies 9 21st October 2009 06:13 AM
Adjustable regulated power supply Ford_V6 Solid State 2 1st April 2003 06:03 PM
DIY - Adjustable Power Supply Design vinay Pass Labs 7 20th March 2002 06:46 PM
