Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th December 2012, 09:02 AM   #1
alibear is offline alibear  United Kingdom
Default CRC Pi Filter resistor value
Hi, I need a 30V supply for a Class A amplifier biased at 1.5A. The transformer I have is 25v secondary, which gives me approx 35VDC after rectifacation and filtering ( with a 1.5 A load ). If I use a Pi filter with an R of 3.3 ohms I can get the reqired 30 V at the second C. Are there any problems with this arrangment for Class A ?
Alan
Old 13th December 2012, 11:10 AM   #2
Essentially I can't see any, unless .....
The question is for a lot of class A amplifiers is what happens
when you run out of current (depending on speaker load ....)
Some enter class B for both voltage swings, some current
limit for one swing and enter class B for the other, some
do a bit of both, and rarely they symmetrically current clip.
Any excess current drawn might need you to uprate the resistor.
FWIW a capacitance multiplier should give you about the same
voltage drop with a lot less ripple (it does not regulate though).
Capacitance Multiplier Power Supply Filter
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
PI-filter (or CLC vs CRC vs C) Cloth Ears Pass Labs 66 6th April 2013 05:29 AM
CRC Filter ? kacernator Tubes / Valves 2 31st July 2009 10:15 AM
crc pi filter tenderland Power Supplies 3 3rd January 2007 06:50 AM
on me more serious note....Aleph 1.2 CRC pi PSU Clarkcr Pass Labs 2 17th September 2004 09:28 PM
Formula for CRC Filter Rarkov Parts 7 21st January 2004 08:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
