#11 | |
90 + ((210/120)^2)*4 90 + (1.75^2)*4 90 + (3.0625)*4 90 + 12.25 102.25 In my opinion you need neither the resistor or the diode. Last edited by FoMoCo; 12th December 2012 at 11:02 PM. Reason: Left out a 2 in the first equation. |
#12 |
Hey there,
FoMoCo was faster than me, regarding the correction of the reflected primary impedance ![]() I am not sure if I understood you right, but if the secondary impedance is 90 ohms in each leg (from center tap to *each* end of secondary winding), then you're safe. If 90 ohms is the total resistance of the secondary (end to end), then it might be a bit low and need resistors. Greetings, Andreas |
#13 | |
"Epilepsy medications are a lot like girlfriends. Sometimes you just have to take what you can get." -- Dr. Mark Quigg |
#14 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Tube rectifiers has been working fine several decades without diodes nor resistors. Thousands of radios, TV and amplifiers are the evidence of it.
The only rectifier that almost always uses a resistor of about 50R was in the half wave rectifiers like 35Z5 or 35W4 who operates directly from power cord. I only suggest to include a fuse in the center leg of the transformer to the chassis in order to prevent any short circuit.
LW1DSE Last edited by Osvaldo de Banfield; 13th December 2012 at 12:50 PM. |
#15 |
Most radios had transformers with much higher secondary resistance.
#16 |
Of course, and also more resistance reflected from primary, given the step up voltage transformer ratio, and also lowest winding (Copper) and core (Iron) quality (And higher looses), all of them can also be reflected as resistance in secondary or primary side, although is more common to reflect them into primary side.
LW1DSE |
#17 |
Oh! This is totally news to me. Thank god I asked you guys this.
The transformer resistance formula is a good thing to know (Never saw it before). I measured the ct to one leg at a time and averaged their two ohm values so all looks right. So it looks like I don't need anything on the legs! nice! I was gonna ask about the fuse eventually. Is it smarter to put it on the primary side or the CT of the secondary? Origionaly I was gonna put it after the switch on one lead. |
#18 |
I'd put it on the primary side. Otherwise the fuse doesn't protect the transformer.
Putting it on the secondary subjects it to higher voltage. You'd also need two fuses, one before each rectifier. The center tap is particularly a bad idea. If one of your rectifiers shorts, it doesn't protect at all against that. No offense. But, it seems that maybe you shouldn't be playing around with high voltage at this stage of the game.
#19 |
Im following these schematics pretty closely but also at the same time, Im getting a lot of unique tips that defy the schematics. Such as LimR values, transformer resistance & fuse placement (as mentioned above). I understand the danger of high voltage but thats why I am raising these questions in the first place.
#20 |
Place the fuse on the hot side and before the switch, that way if the switch develops a short to chassis (I have seen it happen) the local fuse can blow rather than relying on a distant circuit breaker to protect the intervening wiring. Make sure that the chassis is grounded.
I use the series diodes with all modern 5AR4 as it greatly reduces their propensity to fail due to arcing during warm up and during a hot start event. (Supply interruption)
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
| Which tube Rectifier is good enough for 5902 tube amp ? | calico88 | Tubes / Valves | 14 | 30th July 2011 05:15 AM |
| converting tube rectifier to solid state rectifier. | tubo | Tubes / Valves | 26 | 24th December 2009 12:12 AM |
| Beam Deflection Tube Limiter | Michael Koster | Tubes / Valves | 7 | 10th April 2008 09:55 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Tube rectifier for VDIGC tube psu | ebijma | Chip Amps | 2 | 11th March 2004 04:02 PM |
