Strange Behavior w/ Diodes (Heater Supply)
Old 11th December 2012, 03:33 PM   #1
steve516 is offline steve516  United States
steve516's Avatar
Default Strange Behavior w/ Diodes (Heater Supply)
So I've finished my 6SN7/6SL7 phono preamp and I'm experiencing a few issues with the PSU.
Namely, the filament supply has been acting funky. I'm using the 6.3V taps on my power transformer into a bridge rectifier using 20V/40A Schottky's with a 10,000uF cap. At first, I was getting 9V unloaded and only 4.85V loaded (definitely too low). I got the transformer out of an old amp from a friend and I've never been sure of the current ratings for the filament windings, so, since it had an additional 6.3V tap, I hooked that up as well (so windings in parallel) and I had an exact 6.3V loaded. Perfect, except that when I turned it on this morning, one of the schottky's literally exploded with a loud pop.
I can only fathom it has to do with inrush current and the parallel windings, but it's not blowing fuses so I'm really at a loss.
Possibly just a bad diode? I will try and replace tonight, I have 10 or so laying around...
Thoughts?
Steve
Completed: PP 807's, 6SN7/6SL7 Phono Pre
Currently Working On: 808 SE DHT
Old 11th December 2012, 03:39 PM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Try each transformer winding with a purely resistive load to see what you get.
Old 11th December 2012, 04:07 PM   #3
DF96 is offline DF96  England
Your heater windings need an AC current rating of about twice the DC current you want to draw. You may then also need a soft start circuit to avoid blowing the diodes on switch on, because the big cap will be almost a short circuit at first and the cold heaters will quickly discharge it.
AC heaters can be a lot less trouble!
Old 11th December 2012, 04:56 PM   #4
steve516's Avatar
Thanks for the tips. I'll try just running on AC, and see how good my twisted pair wiring really is! :P I already am getting a little bit of hum that I haven't been able to nail down, so I'm cautious but it's worth a shot.
SK
Old 11th December 2012, 05:17 PM   #5
Elvee is offline Elvee  Belgium
Elvee's Avatar
What type number of diode is it?
Also, there is a high risk the other diode of the same rail is damaged: semiconductors generally fail short before they open, and this could mean the other diode also had to sustain a short-circuit current.
It looks like a possible cause, but 10,000uF at such a low voltage is normally not that much for 40A diodes
Possibly, but take care to replace both diodes at the same time, otherwise your stock could vanish very quickly...
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th December 2012, 07:36 PM   #6
steve516's Avatar
OK, so I was mistaken about my diodes. They are type 1N5822. So average forward current of 3A should be fine for my tubes, which at 4x 600mA gives 2.4A. 40V, and max surge current of 80A. So it would seem that I had a bad diode? Will replace all four just to be safe and report back on results.
SK
Old 11th December 2012, 08:34 PM   #7
Elvee's Avatar
The picture is quite different: schottky's are not very resilient compared to ordinary Si diodes of the same caliber, and the surge event now looks much more likely.
That would mean a ~2 x 3A rating for a bridge, but the power factor of a normal rectifier+cap is also in the region of ~0.5, this means that with 2 x 2.4A you are just within the range, but not much more, and with a low impedance winding, you could easily overstress your diodes, both at the start-up and during steady state.
Ordinary diodes like 1N5402 would have no problem coping with such surges, but your output voltage will be insufficient.
Now, I am not sure at all. It could be a fluke, but it could as well be recurrent.
If you have enough of them, you can try with 4 fresh ones, but if it happens again within 6 months, switch for larger ones: 10A in schottky seems more than reasonable for this application.
Old 12th December 2012, 03:24 AM   #8
steve516's Avatar
OK, so replaced all four and actually just completely rewired/ soldered the whole filament supply circuit. All is working well in 6.3V land!
Still have some hum in the preamp, not sure where from yet but I'll squash it accordingly...
Thanks for all the help!
Steve
Strange Behavior w/ Diodes (Heater Supply)Hide this!Advertise here!
Damper diodes, center tapped heater, B+ kegger Tubes / Valves 0 20th January 2010 06:40 AM
Strange Power Supply Behavior saurus Solid State 7 31st October 2008 05:59 PM
Strange DC choke behavior zigzagflux Tubes / Valves 8 7th February 2008 06:13 AM
Strange offset behavior in Aleph 5 Kilentra Pass Labs 6 12th April 2004 06:01 PM
Strange Switchercad behavior capslock Solid State 2 17th April 2003 01:07 AM
Copyright ©1999-2017 diyAudio
