alteration of the power supply from the power amplifier Harman Kardon HK870 at 220.
Old 11th December 2012, 12:30 PM   #1
alexkmp3 is offline alexkmp3  Russian Federation
Default alteration of the power supply from the power amplifier Harman Kardon HK870 at 220.
Greetings! Please inform parameters transaformatora T1. I want to remake it under the power of 220 volts. Power switch is not found. Version of the adapter does not fit, because in addition to the American amp powered devices are a few pieces in the front - and a number of adapters tired. Service manual for my model here Скачать manual Harman Kardon hk870 Service Manual. Most likely, the trans will wind itself, and for this you need to know the options. Like, if I understand correctly, this should limit winding trance T1 and replacing the capacitor C1.
Old 11th December 2012, 01:01 PM   #2
Triodethom is offline Triodethom  United States
Triodethom's Avatar
From the manual it is a 120 volt primary only . So an outside transformer from 220 primary to 120 secondary of 5 amps on primary is the easy way to use this amp. This also called a step down transformer no need to change the hk870 as it is just supply it with 120volt ac . Hope this helps.
Old 11th December 2012, 01:19 PM   #3
Thank you! This is also a good option. However, I want to know the parameters of the native transformer.
Old 11th December 2012, 03:04 PM   #4
Triodethom's Avatar
Very well which ones ?
Old 11th December 2012, 04:39 PM   #5
Interested in power and voltage at the terminals of the windings (blk, brn, org, blu).
alteration of the power supply from the power amplifier Harman Kardon HK870 at 220.Hide this!Advertise here!
Harman Kardon TA5000-X power XFMR dharper8 Tubes / Valves 1 21st November 2009 03:26 AM
Harman Kardon tube Power Transformer ID voxacthirtee Power Supplies 1 27th September 2009 04:54 AM
Harman Kardon HD7600II power supply voltage conversion runethechamp Digital Source 1 26th May 2009 07:00 PM
