Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th December 2012, 12:16 PM   #1
Holty is offline Holty  United Kingdom
Default fuse blowing on power supply
Hi
My first thread in this section. I am not knowledgeable in electronics, so thought you could give me some help.
I have an Antelope Audio Voltikus power supply that powers a dac, which is 18 volts. The power supply has two fuses and it looks like only one of them is blowing, roughly every three to four weeks. I have kept a log of times and which one blows. When i power it down the light goes out slowly, but it is on power up there is nothing, when the fuse blows.
It has been back to the manufacturer once and now it looks like it will be going again. The fuses were changed from 0.8a-250v time delay to 0.5a-250v time delay when it was last back.
Thanks Jim.
Old 11th December 2012, 12:21 PM   #2
keep returning it till the retailer decides to refund or replace.
Make sure they pay postage both ways.
Old 11th December 2012, 01:07 PM   #3
Triodethom's Avatar
Totally agree let them fix it or replace it .
Old 11th December 2012, 02:01 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Try running this apparatus on a series with an incandescent light bulb of about ten times the power drained from this power supply. Observe the filament bright each time the supply is turned on. There may be a short overload at turn on, or the fuse is too close to the initial current surge.
LW1DSE
Old 11th December 2012, 02:09 PM   #5
A T rated fuse (or any fuse) passes a short term current that is many times the rated current.
I would expect the equipment to draw a start up current that far exceeds the normal operating current. The correct fuse would be to allow operation during times of maximum demand. This size of fuse would then allow the larger start up pulse.
An example of this is the use of soft start for transformers.
A 240VA 240Vac transformer will run on a T1A fuse. This fuse will pass 10Apk for a very short period. It will even pass 50Apk if the period is short enough.
This transient pass ability is what allows equipment to start. Match the start current to the start period and the fuse survives, many hundreds of restarts. A 100r resistor will probably allow the T1A fuse to survive using a soft start circuit. The maximum start transient current can't be higher than about 3.4Apk and that can only last a few tens of ms.
Old 11th December 2012, 02:53 PM   #6
Triodethom's Avatar
1. the manual states .8a t fuse but the factory used .5a t fuse .
2. Do both fuses blow or just one and is it always the same one ?
3. Given the slow turn off of the light there may be a problem with the bled (drain) resistor.
4. Have you monitor the ac line voltage at the time of the problem given only every 3 to 4 weeks what time of the day does it happen ?
Old 11th December 2012, 04:12 PM   #7
DF96 is offline DF96  England
The bleed resistor is unlikely to be the problem. Slow turn off means high value, which means less load.
If the unit works OK then try a 1A fuse. Triodethom's idea of checking mains voltage is also worth doing, as this seems to vary more than it used to in many countries.
Old 11th December 2012, 04:41 PM   #8
It is the so called "I²t", of fuses and thyristors.
LW1DSE
Old 11th December 2012, 04:44 PM   #9
Originally Posted by Osvaldo de Banfield View Post
........................ or the fuse is too close to the initial current surge.
If you know the second, then why suggest the first?
Old 11th December 2012, 04:57 PM   #10
Depending on the load type (Capacitive or inductive), a initial current sourge can appear on the input line, as in the case of mains rectifier in SMPS, PC monitors, motor inverters, etc, and if the fuse rating may be overloaded if, for example, the set is used in 110 or 220V mains, as the peack is bigger as mains voltage is bigger. Also, some old sets has a auto 110/220 switching arround AVS08 ST CI and TRIAC, and if this circuit is malfunctioning, it can cause sporadic fuse blown (By example, if the low voltage smooting cap for this IC is dry).
This is the reason for suggest the series lamp test.
LW1DSE
Fosgate amp blowing power wire fuse Methodsofmahan Power Supplies 3 13th March 2012 04:32 AM
Precision Power art series blowing fuse ahardb0dy Car Audio 9 21st February 2012 09:44 AM
blowing fuse on power cable uksteffy Power Supplies 4 25th November 2011 10:21 PM
Peavey 400 blowing fuse on power up Barnacle Solid State 11 2nd February 2009 10:49 AM
Amp intermittently blowing fuse at power up Saurav Tubes / Valves 11 10th January 2005 12:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
