Where to buy power supply AC 17V, 8VA - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th December 2012, 02:00 PM   #11
If you are going to prise open the wall wart . there is not much point .. all you will find inside is a transformer.. The rectification and smoothing is done on the phono amplifier PCB....
Old 11th December 2012, 02:02 PM   #12
Don't open the wall wart.
It may be double insulated. That is a guarantee that it is safe from mains electric shock even in the event of a fault.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th December 2012, 02:24 PM   #13
Thanx Madtecchy ! Splendid translation
Andrew, I have the original wall wart and its working perfectly. i just wanted to upgrade it to a better quality power supply. That was the thought
Old 11th December 2012, 02:27 PM   #14
So to conclude, it does not make any sense to go for an upgrade? Am i understanding right?
Old 11th December 2012, 02:34 PM   #15
FoMoCo is offline FoMoCo  United States
As Andrew said, the rectification and filtering is not in the wall-wart. Replacing it does nothing to help you.
Old 11th December 2012, 03:02 PM   #16
Triodethom's Avatar
Some time ago PS audio found that the transformer before the bridge would effect the sound even though the current demand was far below the transformers output . Given that if you can get a 17 or 18 volt ac output transformer cheap try it and report back . If the power supply in the box is very good there may be little if any effect. Thus do not spend a lot to try a different ac wall wart or transformer . Regards
Old 11th December 2012, 04:14 PM   #17
Crystal Clear. Maybe better option in my situation is to invest in a Main conditioner? I want to put this phono at its best..
Old 11th December 2012, 09:37 PM   #18
My personal opinion is that these sort of things are snake oil.
Something that is well designed should expect to see some sort of trash on the mains and be able to deal with it.
Old 11th December 2012, 10:41 PM   #19
Triodethom's Avatar
Smile No shortage of snakes but the oil is not free
That a big if . It appears a lot of power supplies are not designed to filter out the non primary freq. from the ac line. In a private conversation with Tony Cortasman after he review some filters I ask if as a defense contractor was his ac secured as well as the phone lines . He said of course then I pointed out the the ac line was so heavily filter to prevent spying on his activates related to the DOD that there was no noise on his ac line. Since most of us do not have secured ac coming in to our homes a line conditioner can have an effect.
Old 12th December 2012, 12:15 AM   #20
True. But, if the line conditioner has an audible effect, the designer didn't do their job when designing the equipment. That's not acceptable for a piece of "audiophile" equipment. If it's a cheap piece of equipment, its own flaws will probably mask the line conditioner's effects. At least that's my opinion about it.
Variable AC Power Supply Rino odorico Everything Else 12 14th March 2013 04:56 AM
Power Supply for Class D: 12V AC mulluysavage Power Supplies 5 18th January 2011 11:16 AM
AC motor power supply calucci Analogue Source 21 3rd September 2007 05:36 PM
Copyright 1999-2017 diyAudio
