What should I do with my R-Core transformer
Old 17th December 2012, 11:42 AM   #11
Mooly's Avatar
In your first post you say it needs 10 to 14 Vac input. So almost 19 volts is too high. Does that matter ? Its impossible to advise without seeing the circuit details. For example if 25 volts caps are used then 19 volts ac gives almost 27 volts dc after rectification and smoothing. Assuming that was OK and 35 volt caps were fitted then you have the problem of "what else" this unregulated supply feeds and whether or not the dissipation of any PSU components is being exceeded.
On the basis of what we know I would advise not to use this transformer unless you are 100% confident the above points are covered..
Old 19th December 2012, 03:52 AM   #12
mvorn44 is offline mvorn44  United States
Circuit is as follows. ac input voltage to KBP206 rectifier to 3300uF 50V cap to 220uF 25v cap & 47 Ohm 5% 3W resistor to 7805 & 7809 voltage regulators.
Old 19th December 2012, 06:58 AM   #13
Mooly's Avatar
Without seeing and measuring first hand only you can make the judgement call.
Measure the voltage across the caps with it on. If the 25 volt cap has anything over around 22 or 23 volts across it then its getting close. You have to allow for mains voltage variations.
Old 5th January 2013, 06:14 PM   #14
Tested and working fine. Heatsinks are just warm to touch. Just need a enclosure to complete the project. Thanks for all the help.
Old 5th January 2013, 06:30 PM   #15
Mooly's Avatar
Thanks for the update... great to hear it all worked out.
What should I do with my R-Core transformerHide this!Advertise here!
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
need help with transformer core sss Power Supplies 11 7th November 2006 12:40 PM
Transformer efficiency - Z-11,H-14, c-core, r-core , toroidal flyboi Parts 23 4th May 2006 01:03 PM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
R Core Transformer john-china Pass Labs 0 10th July 2003 02:34 AM
