Is this going to be adequate: MKP Power Caps
Old 4th December 2012, 01:23 AM   #1
bullpeters is offline bullpeters  Australia
bullpeters's Avatar
Default Is this going to be adequate: MKP Power Caps
http://www.ebay.com.au/itm/CDJ-MKP-P...ht_1925wt_1137
Old 4th December 2012, 01:52 AM   #2
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
Hi, I fixed the link. You are going to have to give more information... adequate for what?
You will need to specify where in the PS it will be used, and probably expected load (if it is used for smoothing duties).
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 4th December 2012, 06:59 AM   #3
bullpeters's Avatar
Yeah thought so. Basically 50 uF, valve rectifier, 220 uF to OT, first stage regulated. The Bevois Valley. It's taking sometime . So yes, smoothing cap. I have a good deal on some MKP caps, 1000v, but the postage will kill me. These look cheap. Pls don't sugest electrolytics, I have considered them and I am eating my options
Old 4th December 2012, 04:22 PM   #4
Triodethom is offline Triodethom  United States
Triodethom's Avatar
If there is a choke between the value rectifier and the second cap (220 uF) then yes or at least a resistor to control the current peaks . My preference is choke. Since these are close to you then I would use them.
Old 4th December 2012, 04:32 PM   #5
You could try to find motor run capacitors near to you.
Available in 250Vac and 440Vac versions. considerably cheaper, since motors don't have any Audiophool parameter requirements.
regards Andrew T.
Old 4th December 2012, 04:43 PM   #6
Pano is offline Pano  United States
Pano's Avatar
The item is a Motor Start cap. For this use would Motor Run be any better? They'd cost more for the same values, right?
Old 4th December 2012, 05:19 PM   #7
motor start are rated for short term voltage loading.
I have no idea if there is a de-rating that can be applied for continuous duty.
Check the manufacturer's datasheet for advice on changing from AC voltage rating to continuous DC voltage rating.
They are unlikely to state Vdc rating = 1.4* Vac rating
regards Andrew T.
Old 4th December 2012, 06:26 PM   #8
Pano's Avatar
I have looked. So far can't find any DC ratings at all. Is that good or bad?
Old 4th December 2012, 07:51 PM   #9
bullpeters's Avatar
Yes there is a choke in between
Old 6th December 2012, 03:35 AM   #10
metalsculptor is offline metalsculptor  Australia
Why would you use a motor start capacitor (bipolar electrolytic) if a conventional electrolytic capacitor is unsuitable? 250V motor run capacitors often have a 600VDC rating, insulation fatigues under cyclic potentials making the AC rating considerably less than the DC rating. A 50uF 250VAC motor run capacitor is about the same size as a 1950's vintage 50uF 400V electrolytic.
Is this going to be adequate: MKP Power CapsHide this!Advertise here!
MKP caps: are these for real? taj Parts 28 25th September 2007 08:47 AM
Visaton MKP caps? Asen Parts 4 11th December 2003 04:20 PM
Replacing ceramic caps by MKP?? Duck-Twacy Solid State 6 21st July 2003 11:22 PM
Icel Mkp Caps Piersma Swap Meet 0 5th May 2003 10:45 PM
Wima MKP 10 caps Ilianh Swap Meet 5 12th March 2003 09:29 PM
Copyright ©1999-2017 diyAudio
