diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   smps transformer (http://www.diyaudio.com/forums/power-supplies/224902-smps-transformer.html)
jagdeepsingh2 3rd December 2012 07:09 PM
smps transformer
Hello I need help
I'm making an inverter welder
Transformer data:
E 71/33/32 N87
For 50v output
I have 13 primary turns 0.67mm x 20 wires and 8 secondary turns 0.67mm x 58 wires.
The problem is:
The secondary coil I want to wind with copper foil not with copper wires
So how can I calculate how many turns of copper foil I have to make? And dimensions of copper foil? Please help
KatieandDad 3rd December 2012 07:14 PM
Exactly the same number of turns as for wire.
Wire CSA is the same regardless of if it is foil or wire.
Pano 3rd December 2012 07:20 PM
:cop: Please do not use all caps when posting. Read the forum rules, they are here.
I have fixed your post.
jagdeepsingh2 3rd December 2012 07:27 PM
Originally Posted by KatieandDad (http://www.diyaudio.com/forums/showthread.php?p=3268890#post3268890)
for secondry i have 0.67mm x 58 wires
what size of foil i use please help i'm not understanding
and thanks for quickly reply in other forums they reply after 1 month
jagdeepsingh2 3rd December 2012 07:30 PM
help
for secondry i have 8 turns of 0,67mm x 58 wires
what size of foil have to use please help im not understanding
jagdeepsingh2 3rd December 2012 07:36 PM
Originally Posted by Pano (http://www.diyaudio.com/forums/showthread.php?p=3268899#post3268899)
sorry
SemperFi 3rd December 2012 07:47 PM
Why do u want to use foil? That is only used in planars where sw-freq is very high, b/c that requires low inductance and few turns. It will likely become very capacitive with that many turns.
jagdeepsingh2 3rd December 2012 07:52 PM
Originally Posted by SemperFi (http://www.diyaudio.com/forums/showthread.php?p=3268937#post3268937)
i want to make this
Welding inverter 100A
payloadde 3rd December 2012 08:01 PM
Originally Posted by jagdeepsingh2 (http://www.diyaudio.com/forums/showthread.php?p=3268908#post3268908)
Your secondary wire is 0.67mm in diameter ?
so cross section area (csa) of one strand is pi*d*d/4 = 0.35 mm2, right ?
0.35 mm2 times 58 strands = approx. 20 mm2
so you need at least 20 square mm cross section area of your foil.
Thermal properties of foil may be different, I don't know.
Also, if inverter frequency is high, multiple strands of wire is much better because of skin effect.
jagdeepsingh2 3rd December 2012 08:45 PM
Originally Posted by payloadde (http://www.diyaudio.com/forums/showthread.php?p=3268948#post3268948)
you are a genius man thank you very very much
but one other thing i calculated all with this software diysmps
but one thing is not clear if i have to wind for first primary or secondry turns
Copyright 1999-2017 diyAudio
