What should be the deadtime for Hbridge circuit???
Closed Thread
Old 3rd December 2012, 06:07 PM   #1
billu8660 is offline billu8660  Pakistan
Default What should be the deadtime for Hbridge circuit???
Thread closed due to this being an example of an unisolated power supply that is permanently "live" and consequently potentially lethal. Such topics are against the rules for your safety,
diyAudio Rules
hi,
i am building a Hbridge SMPS with SG3525 and IR2110, the MOSFETS are IRFP460 i need to know what will be the sufficient deadtime for 50khz frequency???
Because MOSFETs are exploding with 880ns deadtime, is deadtime the problem because it works fine with 60Vdc as input but when i apply 310Vdc booooom
Old 3rd December 2012, 06:24 PM   #2
RJM1 is offline RJM1  United States
#1 depends on what MOSFETs you are using and their turn off delay. A schematic would be useful? The turn on delay for the IRFP460 is 18uS, you probably want to be a bit longer than that.
#2 depends on your gate drive circuit.
Old 3rd December 2012, 07:28 PM   #3
SemperFi is offline SemperFi  Wake Island
What kind of monster are u building?
Drain voltage squared is a factor in switching losses, so u dont need to increase the voltage before it goes too far. You need to increase the voltage slower and observe when the devices temp gets critical.
Can you place current transformers in series with drai and gate to check currents? You'd be able to tweak DT that way. Assuming you have a good o-scope.
Old 4th December 2012, 06:59 AM   #4
More possibilities:
Could it be spikes becoming too high as the voltage is increased killing the MOSFET?
Old 4th December 2012, 07:55 AM   #5
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
IRFP460 are quite sturdy MOSfet's but they have a rather large Ciss witch if not charged fast enough it causes slow turn on and so the power dissipated on the mosfets increases with increasing voltage and they cand be destroyed by this, so you need to be sure you have enough gate current for them. Anyway a schematic is the only way for us to determin what is your problem, so do show us what it is.
Have a go at my latest set => Dj Marik -
Trance session live ep. 94
Old 4th December 2012, 08:01 AM   #6
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Or:
Is your flux walking? How did you prevent that in your circuit?
[QUOTE=RJM1;3268831]A schematic would be useful?[QUOTE]
Old 4th December 2012, 09:27 AM   #7
yep. perhaps the duty cycle is becoming too short as the voltage is increased, so short it is not turning the FET on properly....?
Old 4th December 2012, 10:04 AM   #8
MarianB's Avatar
That too could be the reason for failing, but fet's are verry fast devices and 50Khz does not seam that high a freq, if they would have enough gate current deadtime should not be a problem. But until we do not see the exact schematic used all we can do is suppose things.
Old 4th December 2012, 03:29 PM   #9
hi all,
here is the schematic
Old 4th December 2012, 03:59 PM   #10
Are you actually using MUR1560 at the output?
Are you sure you have not blown those already and that is the cause of problems?
Closed Thread
What should be the deadtime for Hbridge circuit???Hide this!Advertise here!
mosfet on-off delays vs fs and deadtime SemperFi Class D 15 17th October 2012 06:00 AM
Problem with IRS2092 Deadtime fanmade Class D 15 26th June 2012 11:51 AM
Best Deadtime Delay Circuit in Class-D Workhorse Class D 28 20th April 2007 03:35 PM
Measuring deadtime Brian Oppegaard Class D 39 21st July 2005 07:23 AM
Copyright ©1999-2017 diyAudio
