modifying number of turns on trafo
Old 3rd December 2012, 01:06 AM   #1
blakdrag is offline blakdrag
Default modifying number of turns on trafo
good day to everyone.herewith is the schematic of the project ive done.
everything is good until now.
i just want to ask if is it possible to add turns on the secondary of the trafo.i used ei-33 trafo from old atx psu.i want to add turn up to let say 50+v.am i going to change the irfz44 or the tl494?
need some experts regarding this.i just want to try it but parts of that project are hard to find here in my place.i ordered them from ebay so i want to ask first to avoid expensive mistakes.
tia
Old 3rd December 2012, 03:44 AM   #2
DUG is offline DUG  Canada
If you are just raising the output voltage (and lowering output current in proportion) I don't think you need to change anything. Except for output diode PIV if required.
If you are raising the output voltage and output power then you may have to change the transformer, the FETs, the Fet's drive.
But I'm not sure why you would need to change the 494.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 3rd December 2012, 04:59 AM   #3
thank's dug
fets are hard to find here in my place.ive search the web about smps with higher voltage output and found that parts are hard to avail so i just thought that what if i'll just modify what ive done but i have to ask experts first.
Old 3rd December 2012, 03:12 PM   #4
powerbob is offline powerbob
I do not understand your question. Are you saying you have already built this smps with an EI33 core and it is working. And now you want to modify it for more voltage on the secondary.
Old 5th December 2012, 01:04 AM   #5
sorry for the late reply so much bz.
yeah i built this one and im asking if it is possible or safe to turn up/add more voltage to secondary.
thank's for the time
Old 5th December 2012, 03:22 AM   #6
“i want to add turn up to let say 50+v"
After 30V you need to be a little more careful with isolation of the primary and secondary. As a minimum use 3 wraps of a high temperature high voltage tape between the 2 winding’s, and also each secondary. You can add more secondary turns, if you have room for them? What is the winding width of your bobbin? I will try to run some numbers.
The primary side is OK with the TL494 and the irfz44 fet’s.
Old 5th December 2012, 08:02 AM   #7
SemperFi is offline SemperFi  Wake Island
Yes u can wind more on the secondary. More windings may give you more ringing. As long as the MOSFETs can handle the voltage spikes, no prob with them. But increasing the voltage by 20% may also increase the current output and thus the power? Will the devices and transformer handle that?
30V? I've done flyback transformers up to 350V without any tape at all for experimentation. I dunno how high a voltage transformer wire handles, but it surely is >30V. If you have high leakeage inductance it may be good to try without tape and interleave as much as possible. If you have too much leakeage capacitance tape between layers will help. It's all trade offs and experimentation is neccesary to find the optimum combination.
Old 5th December 2012, 12:19 PM   #8
TANDBERGEREN is offline TANDBERGEREN  Norway
tia
To produce 50V You need 17 windings in each secondary. (Will give 48V)
Remember that the bobbin used limits the power, so even if You have more voltage on the secondary, You will get less Amps.
Sooner or later you end up with TANDBERG
Old 5th December 2012, 12:30 PM   #9
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
WRONG
You need to know the V/T ratio of the transformer before you can make such wildly innaccurate statements.
Old 5th December 2012, 12:59 PM   #10
didiet78 is offline didiet78  Indonesia
Originally Posted by KatieandDad View Post
WRONG
I don't thing his statement innaccurate. This is switching power supply, so if V/T ratio got wrong, PWM ratio still can be change.
Didiet
modifying number of turns on trafoHide this!Advertise here!
SMPS number of turns vasko Power Supplies 18 16th November 2012 03:15 AM
AV Receiver turns on for a second, then turns off nige838 Solid State 1 16th November 2010 12:46 AM
Teac AG-v8050 home receiver turns off after it turns on eroc1313 Chip Amps 1 20th November 2009 03:18 AM
Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! autolink Car Audio 4 15th March 2009 02:12 AM
Copyright ©1999-2017 diyAudio
