Panasonic TS HA vs BHC Slit-Foils - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th November 2012, 10:21 AM   #1
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
Default Panasonic TS HA vs BHC Slit-Foils
Hi!
I'm building 2 power supplies for a dual mono setup each with 20mF capacitance per rail. I can do this with 2 10000uF 63V Panasonic TS-HA or one 22000uF slit foil per rail. Which cap should I go for? Are the slit-foils worth the extra money?
Thank you.
Kind Regards,
Paulo.
Old 26th November 2012, 10:41 AM   #2
Jogi is offline Jogi  Germany
Yes, they are better than most "normal" lytics. Less technical sounding with better bass and smoother high frequencies, just more musical. But, as you said, they are quite a lot more $, especially when you need more than 2 of them.
Old 26th November 2012, 11:32 AM   #3
What about reliability, they're only rated at 80șC. Is it a concern?
Thanks.
Kind Regards,
Paulo.
Old 26th November 2012, 11:40 AM   #4
I never had any issues with temperature; depends where you want to install them. Most transistor amps are below 50 C internally.
More BHC Slit Foil Capacitors - UK poynton Swap Meet 12 23rd January 2009 08:15 AM
Caps for sale: Panasonic TS-HA 10k 50V BrianDonegan Swap Meet 13 24th October 2005 03:20 AM
Source for BHC / Aerovox Slit Foil caps deandob Parts 6 28th September 2005 08:27 PM
PANASONIC capacitors TS-HA or TS-HB! Other caps? ulysse21 Parts 2 25th March 2004 07:10 PM
Copyright ©1999-2017 diyAudio
